Clutch: Types, Problems & Repair Guide
schnappi
Post11-01-2005, 0:19    Subject: Clutch: Types, Problems & Repair Guide Quote
'The clutch should be able to handle the torque; otherwise, it probably won't last long before the next breakdown. But why would someone install a gasoline engine clutch on a diesel engine? At that point, the clutch would definitely give up. Even if the torque is 20% higher, it might last for a while, but otherwise, I doubt it would last more than 5,000 km. You can even see that even new clutches that have been 'chipped' sometimes slip.'
Translated on 27-10-2026, 11:17.
Post11-01-2005, 6:58    Subject: Clutch: Types, Problems & Repair Guide Quote
Um - why are you writing this here?
Did you accidentally click the "new topic" button instead of the "reply" button?
Post11-01-2005, 7:48    Subject: Clutch: Types, Problems & Repair Guide Quote
The rest is here https://community.dieselschrauber.org/en/viewtopic.php?t=8211&highlight=.
Translated on 27-10-2026, 11:18.
schnappi
Post11-01-2005, 14:30    Subject: Clutch Repair: Symptoms, Causes & Solutions Quote
Oh yes, sure! Sorry, I didn't pay attention icon_redface.gif.
No new posts Clutch Slipping: Effects on Engine Power and Performance Diesel Engine Technology
