RPM decreases on the G4 AXR.
TDI-PanTheR
Post08-01-2005, 13:21    Subject: RPM decreases on the G4 AXR. Quote
My friend has a problem with his Golf 4 AXR. Specifically, the engine speed often drops from around 2000 RPM to 1500 RPM when accelerating in 4th gear. Then the engine speed and the engine rev up normally.
He is now with VW and they said that it was the clutch. However, he also told them that something was slipping. I think they just wanted to sell him a new clutch for 1000€. The car has just 40,000 miles on it.
Also, wenn die Kupplung ist, dann sinkt der Drehzahl nicht, sondern steigt eher, oder nicht? Oder sie würde nicht plötzlich bei 2000 U/min wieder anspringen und deswegen abfallen, weil bei 2000 U/min das größte Drehmoment anliegt. I would certainly say...
Error memory is empty.
panther
Post08-01-2005, 18:36    Subject: Re: RPM drops when using G4 AXR Quote
TDI-PanTheR wrote:
My friend has a problem with his Golf 4 AXR. Specifically, he often experiences a drop in engine speed from around 2000 RPM to around 1500 RPM when accelerating in 4th gear. Then the engine speed stabilizes and the engine runs normally.
In the 4th. According to the gauge, 500 rpm corresponds to approximately 35 km/h, which means that the car would have to slow down even further when the accelerator is pressed.
IMO, one wouldn't choose such a "gentle" description in this case -> somehow, the whole thing doesn't feel right to me.
Also, wenn der Motor nicht mehr läuft, dann sinkt der Drehzahlmesser nicht ab, sondern steigt eher an, oder?
Basically, yes.
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 4B: Faulty TV Tuner - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 Documentary: Fuel Drop After Reserve (1999) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ratio of alternator speed to crankshaft speed with ribbed... Diesel Engine Technology
No new posts Starter Motor: RPM to Start Engine On-Board Diagnostics (OBD)
No new posts Alhambra/7M - KI occasionally fails Electrical Systems, Vehicle Electronics, Multimedia
No new posts Engine Power Loss: Check Spark Plug Coil Diesel Engine Technology
