Passat Engine Noise: Causes & Solutions
AfnFahrer
Post06-01-2005, 23:10    Subject: Passat Engine Noise: Causes & Solutions Quote
Hello!
Maybe someone has an idea.
My Passat (1998 AFN model) is now making a significant rumbling noise when turning left.
Average performance when driving straight, and almost no performance when turning right.
The rumbling noise disappears when the clutch is disengaged.
Furthermore, the rumbling noise is clearly noticeable when turning, as well as when driving straight.
I've also searched the forum, but I haven't found an answer regarding changes in direction.
Greetings.
Michael.
Translated on 17-09-2026, 14:04.
Post07-01-2005, 8:53    Subject: Passat Engine Noise: Causes & Solutions Quote
Hi there.
Is the 98 AFN a 3B engine? Does it have a longitudinal engine layout?
For transversely mounted engines (e.g., the AFN in the 3A), I would strongly suspect the flexible pipe - which is also easy to check:
Start the engine and, by hand, feel the pipe to see if any noises change.
I don't know to what extent the bellows of the linear motors are also susceptible to this issue, but the test is the same and is definitely worth doing.
Translated on 17-09-2026, 14:06.
Georg-TDI
Post07-01-2005, 9:10    Subject: Passat Engine Noise: Causes & Solutions Quote
Defective engine mounts, either one or more, could also be the cause.
There have been some problem descriptions related to that already.
Here's an example: https://community.dieselschrauber.org/en/viewtopic.php?t=6483&highlight=motorlager
Start the engine, with someone at the controls keeping the clutch engaged in a higher gear under load. At the same time, an assistant applies force to the engine, tilting it in the same direction as the reaction torque of the engine under load. If the engine mounts are already worn or defective, this will reveal the knocking noises.
Best regards, Georg.
Translated on 17-09-2026, 14:07.
AfnFahrer
Post07-01-2005, 9:51    Subject: Passat Engine Noise: Causes & Solutions Quote
First of all, thank you for your reply.
Unfortunately, clutch slippage is no longer an option, as I almost have to fully release the pedal to engage the clutch.
The error description from 'Dieselpaul' is exactly the same as the one I'm getting on my Passat.
When I turn off the engine, the whole car shakes.
The exhaust system might also be under stress, as the rumbling noise became more pronounced after tightening the front axle support, which had simply come loose during driving.
P.S. Mileage approximately 230,000 km.
Translated on 17-09-2026, 14:08.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF Not Fitting: Twintec on VW Passat 3BG - Rumble? Diesel Engine Technology
No new posts BLS Train Noise: Sudden Roar / Pendulum Support? Diesel Engine Technology
No new posts Golf 4 Noises After Control Arm Replacement Transmission, Chassis, Body & Interior
No new posts Golf 3 Engine Idling High: Fix It Now! Diesel Engine Technology
