Hello everyone.
Okay, I have a VW Vento TDI 1.9 with engine code 1Z. It has approximately 220,000 kilometers on the clock, and I had it chipped about 150,000 kilometers ago.
So far, everything has been running smoothly, except for two mass airflow sensors (apparently a common VW issue) that I had to replace. Lately, it's been making a rattling noise, and I don't know why. I once read an FAQ and suspected the mass airflow sensor, so I tried cleaning it, but it didn't help; the same symptoms persist.
'Sometimes, when I accelerate, I get normal and good acceleration. However, if I press the gas pedal too much, the engine starts to sputter.'
'But usually, I give it gas, and I notice it accelerates, but then it falls into a power dip, and it starts sputtering endlessly. I actually feel like too much fuel is getting in. I did a test and disconnected the hose from the crankcase ventilation system, and sure enough, the sputtering stopped, but the performance was also reduced.'
'I've also replaced all the vacuum hoses and pressure hoses, but that didn't help either. The air filter and fuel filter are all okay. I don't think the turbo is the problem. I suspect that the fuel injectors might be the issue, but I'm not sure if that would manifest in this way.'
I hope someone knows about this problem and can help me!
zoom
