Which Motor Oil: Best Choice & Guide
dj1
Post11-01-2005, 9:16    Subject: Which Motor Oil: Best Choice & Guide Quote
After my chip tuning, the tuner recommended using a pump-injector motor oil.
Now the question is, which oil should I use?
Is it even sensible to use, for example, the engine oil from a Golf 4 PD (110 kW) in a Golf 3 TDI (AFN)?
Thank you for your replies!
DJ.
Translated on 25-08-2026, 17:10.
Bee
Post11-01-2005, 9:45    Subject: Which Motor Oil: Best Choice & Guide Quote
No, it is not advisable to use a PD oil that meets the 506 01 specification!
Yes, it can be beneficial to use an oil that, in addition to the necessary approval for your engine, also has the 505 01 approval (PD without LL). For example, LM's DIESEL HIGH TECH 5W-40.
Did the tuner provide any justification for their statement?
Oils meeting specification 506 01 (PD with LL) have a reduced HTHS value, which means these oils MUST NOT be used in your engine!
'Micha'
Translated on 25-08-2026, 17:11.
Post11-01-2005, 10:01    Subject: Best Motor Oil: Which One Is Right? Quote
dj1 wrote:
GOLF III TDI (AFN), 156.4 hp, 349 Nm
Do the data originate from a test bench?
If the clutch coupling can withstand almost 150% of the nominal torque without slipping, I should be surprised.
Do you have "before" and "after" DZR (dental zirconia restoration) times?
Translated on 25-08-2026, 17:13.
dj1
Post11-01-2005, 11:34    Subject: Which Motor Oil: Best Choice & Guide Quote
Yes, but I can't remember it as well anymore icon_redface.gif. He just said it would be better...
I think I'll just call him and then post his statement.
Thank you.
DJ.
Translated on 25-08-2026, 17:14.
dj1
Post11-01-2005, 11:37    Subject: Best Motor Oil: Which One Is Right? Quote
Do you have pre- and post-procedure DZR times?
Yes, the data comes from a rolling dynamometer.
The clutch didn't last long, or rather, it's been slipping for 1000 km since the tuning . I'm still looking for a clutch for the Golf 3.
Sorry, but how does the DZR timing work?
Translated on 25-08-2026, 17:15.
Post11-01-2005, 11:50    Subject: Best Motor Oil: Which One Is Right? Quote
dj1 wrote:
Sorry, but how does that work with the DZR times?
Take a look at the specialized articles.
Translated on 25-08-2026, 17:17.
dj1
Post11-01-2005, 13:08    Subject: Best Motor Oil: Which One Is Right? Quote
Oh, this is complicated... icon_redface.gif icon_redface.gif icon_redface.gif
No new posts Debris and fragments in engine oil bind General Tips
No new posts Best Engine Oil: Which One to Choose? Diesel Engine Technology
No new posts BMM with DPF. Which engine oil? Diesel Engine Technology
No new posts Best Motor Oil: Which One to Choose? Diesel Engine Technology
No new posts Which engine oil for WIV? Diesel Engine Technology
