VAG-COM OBD-II Compatibility Test
smith2
Post11-01-2005, 8:39    Subject: VAG-COM OBD-II Compatibility Test Quote
Hello everyone,
I have a small problem.
I have an DRV KL-license for VAG-COM. Now I have a new laptop.
'...but unfortunately, it doesn't have a serial port.'
Yesterday, I tried the whole thing using a USB-to-COM adapter.
Result: The connection test is working, but the connection to the control units is not working.
It recognizes the MSG and then returns to the main menu in VAG-COM - so it works.
No. The OBD-II compatibility test failed with the following error message:
Test status: Test complete.
Result: Incorrect sync byte: $BD.
Please try again.
What settings do I need to change for it to work? Or is it a problem with the USB-to-serial adapter? Would it make sense to try a different USB adapter?
Thank you for your help.
cu smith2
Translated on 27-10-2026, 12:37.
wolfi_b
Post11-01-2005, 8:45    Subject: VAG-COM OBD-II Compatibility Test Quote
Or could it be due to the USB-to-Serial adapter?
Exactly that.
The search should yield some results.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 27-10-2026, 12:39.
Theresias
Post11-01-2005, 14:36    Subject: VAG-COM OBD-II Compatibility Test Quote
Since you already have a software license, you could, for example, purchase a genuine USB diagnostic interface here in our shop. Your license will then be applied to the purchase, even if it's from DRV.
The advantages are obvious: no more USB issues, and you can also use the latest versions of VAG-COM.
smith2
Post11-01-2005, 14:50    Subject: VAG-COM OBD-II Compatibility Test Quote
What will the fun cost?
I will first try a different USB-to-COM adapter.
If that doesn't work either, then I will consider your suggestion.
cu
smith2
Translated on 27-10-2026, 12:40.
Theresias
Post11-01-2005, 14:54    Subject: VAG-COM OBD-II Compatibility Test Quote
A similar system costs 349 EUR in this shop. However, 60 EUR will be deducted and credited from Rainer Kaufmann's existing licenses.
Just reach out to the shop/forum administrator.
Translated on 27-10-2026, 12:41.
