roorback wrote: |
For cost reasons, I have considered equipping my V70 TDI with the Audi 5ZY 2.5L engine with 5 injectors using a needle lift injector system. I can get these relatively cheaply, at about €110 each - the 5 original ones would cost me about €1000.
is that a technical problem? |
Yes, the fuel injection lines for the 4 "normal" injectors will not fit the NHG parts.
Trying to bend them would likely be pointless, as they will be too short, and there is also a risk of cracks or fractures.
