Tribune.Inc Guest
16-01-2005, 17:50 Subject: Tuning Chip for 1Z Engine |
'I once had the engine control unit (ECU) of my AUDI 80 1.9TDI 1Z, manufactured in May 1993, inspected, and it turned out that it had been opened before, specifically by ***. There was an *** quality seal on the ECU. I then examined the circuit boards and found '*** Tuning Part 1/2' on both EEPROMs. I wrote down the numbers on the EEPROMs, and they were identical: B57 922, U1480532, 1989. However, since my Audi isn't delivering the performance it probably should with this *** tuning, I wondered if these [EEPROMs] might somehow be deactivated or something!'
Please don't yell at me if this is complete nonsense. I don't know anything about this area!
Now, I wanted to ask you if it's even possible, and how I could activate them if that's the case?
Thank you in advance!
I also tried using the search function, but unfortunately, I couldn't find anything specific.
Michael.
Translated on 17-09-2026, 11:53.
Tribune.Inc Guest
17-01-2005, 19:40 Subject: Tuning Chip for 1Z Engine |
Is there nobody here who can help with something?!?
Translated on 17-09-2026, 11:55.
Rudi Guest
17-01-2005, 21:23 Subject: Tuning Chip for 1Z Engine |
B57922 are 87C257 EPROMs that were specifically manufactured for Bosch.
If your car is actually running completely stock (  stock ECU),
'Did the previous owner possibly acquire the STG (presumably a component or part) from *** due to a sale or because it didn't meet their expectations?'
have it downgraded.
Rudi
Translated on 17-09-2026, 11:56.
faz Blaumann
1994 Audi 80 Premium Support
18-01-2005, 11:09 Subject: Tuning Chip for 1Z Engine |
"Note:"
The DZR (direct-injection resonance) system doesn't work very well with the older Audi 1Z engine.
Reason: The maximum torque is only achieved at 2300 RPM in this case, not at 1900 RPM. However, the DZR (presumably a specific system or requirement) requires a TDI torque curve with the maximum torque occurring at 1900 RPM.
@Tribune.Inc
I can't imagine that the chips were supposed to be "deactivated" in any way. At most, the *** chips may have had their original serial numbers overwritten. MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 17-09-2026, 11:57.
Profile PM Garage |
Rudi Guest
18-01-2005, 11:36 Subject: Tuning Chip for 1Z Engine |
As a starting point or when compared to other early TDI models, the DZR is better than nothing.
Otherwise, reading out the EPROMs and comparing them to the original software would be the solution.
Safe route.
It's highly unlikely that anything is disableable (or enableable) there, as the EPROMs are only...
It has the original size (and therefore cannot be switched to a second bank).
Rudi
Translated on 17-09-2026, 11:58.
Tribune.Inc Guest
18-01-2005, 18:13 Subject: Tuning Chip for 1Z Engine |
Thank you for your quick responses!!!
Michael.
Translated on 17-09-2026, 11:59.
Tribune.Inc Guest
18-01-2005, 19:29 Subject: Tuning Chip for 1Z Engine |
'But I have one more question regarding the small black box with the connection for a pressure hose... should there be one connected to it, or is it not that important? There is no opening for it on the control unit housing itself!'
Michael.
Rudi Guest
18-01-2005, 21:11 Subject: Tuning Chip for 1Z Engine |
No - that's the sensor for the ambient air pressure.
Rudi
Translated on 17-09-2026, 12:00.
wolfi_b Profi-Schrauber
19-01-2005, 8:29 Subject: Tuning Chip for 1Z Engine |
Your 1Z has an external boost pressure sensor! 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Tribune.Inc Guest
19-01-2005, 14:42 Subject: Tuning Chip for 1Z Engine |
'Thank you very much!'
Michael.
