DIY GRA for A6 2.5TDI (C4) - Build/Pinout?
sat24
Post14-07-2004, 0:22    Subject: DIY GRA for A6 2.5TDI (C4) - Build/Pinout? Quote
Hello everyone,
Before my next vacation, with 2800 miles of driving, I finally want to install the cruise control. I don't want to use the original blinker levers, but instead, I want to mount the switches in a free space on the center console. Unfortunately, I can't find a wiring diagram for the blinker levers (only for the gasoline engine with a separate control unit, which is much more complicated). Here's what I have:
The pins 24, 30, 45, and 48 on the MSG are inputs for the GRA switch. Furthermore, a cable is required from fuse 64.
Now, let's guess: the cable from the fuse has 12V when the ignition is on and must be connected to the individual inputs.
Which pin/combinations cause what now?
GRA on, Record, Stop are the functions to be activated. Could someone please help me identify the pins or provide a suitable schematic?
Greetings and thanks
Kai
martin119
Post19-01-2005, 7:49    Subject: DIY GRA for A6 2.5TDI (C4) - Build/Pinout? Translating...
[Translating...]Hallo,
würde mich auch mal interessieren.
MFG
Martin
wolfi_b
Post19-01-2005, 8:57    Subject: DIY GRA for A6 2.5TDI (C4) - Build/Pinout? Translating...
[Translating...]
Am Ende dieses Artikels ist der GRA- Schalter abgebildet.
http://www.meckisfaq.de/bilder//gra.pdf
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
martin119
Post19-01-2005, 12:28    Subject: DIY GRA for A6 2.5TDI (C4) - Build/Pinout? Translating...
[Translating...]Dank, aber ich glaub das ist nicht das richtige.
Ich wollte mir in meinen AEL nur einen Taster einbauen, zum einschalten, Geschwindigkeit halten. Weiss jemand, an welche Pins des Steuerteils ich das anschliessen muss?
MFG
Martin
wolfi_b
Post19-01-2005, 12:59    Subject: DIY GRA for A6 2.5TDI (C4) - Build/Pinout? Translating...
[Translating...]
sat24 wollte den Schaltplan des GRA-Hebels haben, und der ist bei sehr vielen Audis gleich.
Nachdem du geschrieben hast das würde dich auch interessieren, hab ich das gespostet.
Wenn du einen Anschlussplan an das Steuergerät brauchst, dann schlage ich vor du gehst zu VAG und lässt dir den Plan kopieren! Allerdings ist in diesen Plänen die Beschriftung Aufn-Ein-Aus-Aus nicht drauf, weshalb do oben genannnten Plan brauchst.
Ausserdem wirst du das mit einem Taster nicht lösen könne. Du brauchst zumindest noch einen Schalter.
1993 Audi 80 B4 1Z
sat24
Post20-01-2005, 0:11    Subject: DIY GRA for A6 2.5TDI (C4) - Build/Pinout? Translating...
http://www.24max.de/audi-documents/TDI_STG/A6_C4_MJ95_003.pdf Seite6
Ich würde sagen Pin 24 und 30 am MSG verbinden (ev noch auf 12V [Kl15/Pin55], ich weis nicht wo die 39 im Schaltplan her kommt, Sicherung 64 wurde bei Mecki mal genannt) und über Taster an Pin 48. Wer die Aufnehmen Funktion noch braucht, macht noch einen Taster zu Pin 45 parallel. Die Aus-Funktion braucht wohl keiner.
Kann das einer bestätigen und das mit dem Anschluß 5 des Original-Schalters noch erklähren, wo der genau drann muß.
sat24
martin119
Post21-01-2005, 8:13    Subject: DIY GRA for A6 2.5TDI (C4) - Build/Pinout? Translating...
[Translating...]Hi,
also nur Pin 24 + 30 verbinden und Pin 48 über einen Taster an Sicherung 64 (12V +) oder 24 + 30 verbinden und über Taster an 48? icon_confused.gif
Sat24, hast Du es schon probiert?
Gruss
Martin
sat24
Post21-01-2005, 16:51    Subject: DIY GRA for A6 2.5TDI (C4) - Build/Pinout? Translating...
XXX ---+
Pin24 --+
Pin30 --+
Pin48 --+
Wobei XXX wahrscheinlich 12V sind. Wenn es wieder warm wird, mach ich mich wieder ans Auto und teste das.
No new posts Build your own cruise control? Diesel Engine Technology
No new posts How to Build Accurately: A Step-by-Step Guide Diesel Engine Technology
No new posts Build your own VAG connector Diesel Engine Technology
This topic is locked, you cannot edit or reply. Build your own water injection system Diesel Engine Technology
