duesentausch NHG - need help
roorback
Karma: +1 / -2   Thank you, like it!
Post29-01-2005, 20:58    Subject: duesentausch NHG - need help Quote
hello,
"For cost reasons, I've been considering equipping my V70 TDI with the Audi 5ZY 2.5L engine, which uses five injectors with a needle lift injector system. I can get these relatively cheaply, at around €110 each, while the five original injectors would cost me about €1000."
Is that a technical problem?
Thank you for the help.
"Greetings, Uwe."
roorback
Post29-01-2005, 21:00    Subject: duesentausch NHG - need help Quote
Are there perhaps other types that would fit?
Post29-01-2005, 23:59    Subject: Re: NHG exchange - need help Quote
roorback wrote:
For cost reasons, I have considered equipping my V70 TDI with the Audi 5ZY 2.5L engine with 5 injectors using a needle lift injector system. I can get these relatively cheaply, at about €110 each - the 5 original ones would cost me about €1000.
is that a technical problem?
Yes, the fuel injection lines for the 4 "normal" injectors will not fit the NHG parts.
Trying to bend them would likely be pointless, as they will be too short, and there is also a risk of cracks or fractures.
golfschrauber1981
Post30-01-2005, 10:40    Subject: duesentausch NHG - need help Quote
Trying to bend them would likely be pointless, because they will be too short, and there is also a risk of cracks / fractures.
Furthermore, the lengths of the individual lines no longer match (all paths from the pump to the nozzle opening must be the same length).
This is actually achieved using the curves in the pipes.
No new posts Ford Galaxy: Limp Mode - Get Help Now! On-Board Diagnostics (OBD)
No new posts Golf 3 1.9 TDI: Glow Plugs Not Working? Diesel Engine Technology
No new posts SEO: "Best SEO Tools: Improve Your Rankings Now" Diesel Engine Technology
No new posts Help! I need assistance. Diesel Engine Technology
