Pre-heat control keeps blinking after 10 cent tuning.
andreas
Post24-04-2002, 13:47    Subject: Pre-heat control keeps blinking after 10 cent tuning. Quote
Hello everyone!
I'm having a problem where, after performing a 10 cent tuning, the 'engine check' light stays on constantly.
Even with an expanded Poti and a restart, the display still flickers annoyingly.
Can the blinking of the warning light be reset somehow?
I find it amazing (I'm driving a 3B, 07/97, 66 KW, AHU), that the
Resistance value in my tuning, with 420 Ohms (this is the best!).
Should anyone be able to help me with the annoying control light:
Thick thanks in advance!!!
Andreas
Michael II
Post24-04-2002, 13:58    Subject: Re: Quote
with the "annoying control light", your control unit wants to communicate with you
indicate an error, or emergency mode.
If I understand correctly, the warning light also flashes when
Continue dismantling and restoring to the original state.
This means that your control unit has detected a permanent error that cannot be fixed by restarting.
So, am besten: Get the fault codes read and post the results here.
Tschüss
Michael II
andreas
Post24-04-2002, 22:47    Subject: Blinken is gone! Quote
Hi Michael!
I've been experimenting a bit: by 'preheating', I was able to stop the blinking.
Now, a switch is used to activate the 'tuning' function as needed and to bypass the control unit's check time!
Thank you and best regards.
Andreas
No new posts Doku Polo 9N, Kontrolle Airbag OFF glimmt ständig Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow plug light flashing Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Climatronic display blinking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 10 Cent Tuning Diesel Engine Technology
No new posts 10 Cent Tuning T4 2,5 75kW Diesel Engine Technology
No new posts 10 Cent Tuning warum Pin 2 und 3 ?????? Diesel Engine Technology
No new posts Diodes 20 cent tuning Diesel Engine Technology
