Low RPM = High Fuel Consumption
Mephisto
Karma: +14 / -1   Thank you, like it!
Post05-02-2005, 19:00    Subject: Low RPM = High Fuel Consumption Quote
Hi everyone,
Here are two things that bothered me about my AXR with EU4, with 10,000 km on the odometer:
1.) On my slightly downhill home stretch, which I ride with LL mode, the transition from coasting to LL control was happening too early. (--> Slight jolting --> "search function" --> a large number of helpful articles)
2.) AGR.
The following actions were taken:
1.) Der LL-Defaultwert wurde von 32768 (903U/min) auf 32708 geändert. Doch: Statt einem geringeren Verbrauch in der MFA erhöhte sich der Verbrauch von 0,7 l/h auf 0,8 l/h. Man könnte argumentieren, dass die Dieselmenge pro Einspritzung vom Steuergerät angehoben werden muss, um den Motor am drehen zu halten, und dass die Verbrennung dann nicht mehr so effektiv ist. Aber: Das passt nicht so recht mit dem Luftüberschuß beim Diesel zusammen. Erklearning?
Could other AXR drivers please post their LL consumption and LL RPM values (perhaps with a note about what, when, and why was "adapted"?)
I am now using a value of 32750, which corresponds to 882 RPM. At this speed, the mass flow meter (MFA) is showing just 0.7 l/h, not 0.8 l/h.
"Since I want to refrain from any modifications for the time being, I have adjusted the default value of the mass flow controller (MFC) setpoint from 32768 to 33638 (the highest acceptable value)."
Here in the forum, there is only one report that describes this being done with the AXR (apart from hints that "something was adjusted"). However, this report also mentions that the AGR was installed using metal brackets.
Is there a benefit to installing a gasket with a reduced cross-section, as mentioned in a post?
I will be testing some things tomorrow on a closed section of road. If anyone in the forum is interested in specific data, please let me know BEFORE tomorrow morning.
"Micha"
Translated on 04-10-2026, 16:59.
Post05-02-2005, 21:04    Subject: Low RPM = High Fuel Consumption Quote
I wouldn't put too much weight on the LL instantaneous consumption displayed on the MFA. Mine (in the ASZ) shows 0.5-0.6 l/h with a cold engine, and usually 0.7, sometimes even 0.8 l/h when the engine is warm. This is without the air conditioning and with the same electrical consumers, as far as possible.
Translated on 04-10-2026, 17:02.
No new posts Audi A3 (8L): High Mileage Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: High oil consumption, AFB and AKN engines Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter, Year 2012/2013, High Standby Current Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 TDI 1Z engine cuts out at high RPM Diesel Engine Technology
No new posts TDI engine sputters at high RPM Diesel Engine Technology
No new posts Solved: 1Z - Power only at high RPM Diesel Engine Technology
No new posts High fuel consumption at 1Z, what should I do? Diesel Engine Technology
