tiptronic without value for soft coding ?!
PeterK
Post01-02-2005, 10:16    Subject: tiptronic without value for soft coding ?! Quote
I have a tiptronic GKB FST, manufactured in 2001. When using VAG-COM, no values are displayed for soft coding. Is this normal? Can VAG not read this information, or is there a fault here?
Additionally: Can anyone confirm the motor control unit (ECU) coding for an ATD with FST Tiptronic?
nochwas: what is the probability of having a false odometer reading if the display shows 00000 and the text elsewhere indicates 02000?
peter K.
Address 01 -------------------------------------------------------
Controller: 038 906 019 FF
Component: 1.9l R4 EDC G010AG 1449
Coding: 00001
Shop #: WSC 01317
WVWZZZ1JZ2W252xxx VWZ7Z0A4156586
No fault code found.
Address 02 -------------------------------------------------------
Controller: 09A 927 750 N
Component: AG5 Gear 09A 0163
Address 17 -------------------------------------------------------
Controller: 1J0 920 846 C
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 17114
Shop #: WSC 00000
golf iv variant
atd 100ps tiptronic
76+ Tkm
t4 womo
aab 78ps und 4 betten, küche, aussendusche
133+ Tkm
Uwe@Ross-Tech
Post01-02-2005, 16:59    Subject: tiptronic without value for soft coding ?! Translating...
[Translating...]Welche version von VAG-COM hast du da benutzt?
-Uwe-
PeterK
Post01-02-2005, 17:26    Subject: tiptronic without value for soft coding ?! Translating...
[Translating...]
die alte 3.11xy,
wobei ich per google gefunden habe, das es sowas gibt (tiptronic ohne codierung).
Peter K
golf iv variant
atd 100ps tiptronic
76+ Tkm
t4 womo
133+ Tkm
Theresias
Post01-02-2005, 19:59    Subject: Re: tiptronic without value for soft coding ?! Quote
Additionally: Can anyone confirm the engine control unit (ECU) coding for an ATD with FST Tiptronic?
Coding: 00001
Shop #: WSC 01317
The coding is OK, because at the ATD, the Tiptronic has no influence on the coding.
See: http://de.openobd.org/vw/golf_1j.htm#01
PeterK
Post01-02-2005, 21:40    Subject: tiptronic without value for soft coding ?! Translating...
[Translating...]
golf iv variant
atd 100ps tiptronic
76+ Tkm
t4 womo
133+ Tkm
Theresias
Post01-02-2005, 23:50    Subject: tiptronic without value for soft coding ?! Translating...
Also, was mir sponatn einfällt ist erstmal 'ne neue Software Version zu testen.
311.x ist dann doch schon 'out of date'.
Kommst halt einfach mal vorbei, ist alles in aktueller Variation hier vorh. dann sollte man den Fehler finden.
Außerdem such ich eh noch ne Möglichkeit um ein paar Labelfiles live zu testen. icon_wink.gif
PeterK
Post06-02-2005, 21:49    Subject: tiptronic without value for soft coding ?! Translating...
[Translating...]
n'abend,
könnte man ja mal in's auge fassen ..., momentan geht das auto nochmal zur garantiereparatur zurück, mal sehen ob's hilft ...
Peter K.
golf iv variant
atd 100ps tiptronic
76+ Tkm
t4 womo
133+ Tkm
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Bremsflüssigkeits-MIL ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tiptronic A6: Gap Between Gears - Problem? On-Board Diagnostics (OBD)
No new posts A3 8L, year 1999, ALH engine, with and without automatic ... Upload
No new posts 2,0 TDI ohne Leistung Diesel Engine Technology
No new posts AXR Log: 150 Ohm vs. No Tuning Upload
