5-Cylinder 2.5 TDI: Differences & Questions
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post20-11-2007, 14:42    Subject: 5-Cylinder 2.5 TDI: Differences & Questions Quote
I would like to compare the following engines:
2.5 TDI engine from Audi 100, type 44, engine code 1T.
against
2.5 TDI engine from Audi 100, type C4, engine code AAT.
What is the nozzle opening pressure of the nozzles?
What is the diameter of the holes in the nozzles?
Are the injectors from the 1T engine the same type as those used in the AAT, with a 5-hole design?
Could you take an AAT engine block and add the 1T injectors and the 1T ESP (electronic stabilizer)? Would the engine then run smoothly? (Of course, the MSG [engine control unit] and other components would need to be from the 1T).
I'm a little concerned that the geometry of the pistons from the AAT and 1T engines might not be the same, and therefore the spray pattern of the 1T injectors might not be compatible with the AAT pistons.
Thank you and best regards.
Jens.
Marcus "Ar Gwenn": Für uns sind Leute arm, weil sie mit einem Eselskarren unterwegs sind, für sie sind wir arm, weil wir ein Leben lang dafür arbeiten und Geld verdienen müssen, um uns im Alter von wildfremden Leuten pflegen zu lassen.
Translated on 29-09-2026, 5:28.
Jens 16syncro
Post22-11-2007, 10:03    Subject: 5-Cylinder 2.5 TDI: Differences & Questions Quote
How can I find information about the nozzles for the 1T engine?
According to VW documentation, the 1T and early AAT engines use the same pistons, so there are no differences there.
I would be interested in knowing the nozzle hole size of the 1T nozzles.
Jens.
Translated on 29-09-2026, 5:30.
Held467
Post22-11-2007, 11:18    Subject: 5-Cylinder 2.5 TDI: Differences & Questions Quote
Hello.
As far as I know, the 1T engine has 260 injectors in the valve springs, and that's why it doesn't meet Euro 2 standards. I'm not sure what else is different.
Dirk
Translated on 29-09-2026, 5:31.
christians
Post22-11-2007, 13:57    Subject: 5-Cylinder 2.5 TDI: Differences & Questions Quote
"I have no idea about the diameter, but the 1T model also had a dual-spring clip."
Gruß Christian
Translated on 29-09-2026, 5:32.
No new posts VE Injection Pump Data: 5-Cylinder Engine Performance Technical Data
No new posts VE Injection Pump Data: 4-Cylinder Engine Performance Technical Data
No new posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
No new posts Tuning: Factory vs. Aftermarket & FAQs Diesel Engine Technology
No new posts A few questions (I'm a diesel newbie) Questions about que... Diesel Engine Technology
No new posts V6 TDI: What do you think? Diesel Engine Technology
No new posts Wer hat alles nen DPF und loggt viel dazu ? On-Board Diagnostics (OBD)
