Spark Plug Fouling: Causes and Solutions
Zettelmeyer
Post21-02-2005, 10:38    Subject: Spark Plug Fouling: Causes and Solutions Quote
I recently replaced two faulty glow plugs in my Passat 3B with engine code AHU, and I noticed some brown deposits. Could this be a sign of faulty injectors? However, the glow plugs weren't burned out, and the fuel injection timing was corrected about 10,000 km ago (it was significantly delayed). I also don't know how long the car was running with the defective glow plugs, as I only bought it in August.
I suspected the nozzles because the car doesn't start immediately (takes about 2 engine revolutions), it runs very unevenly when cold, and it doesn't reach its maximum speed.
'No errors are stored, fuel consumption is normal. I haven't performed a compression test yet because there is no excessive oil consumption (approximately 0.5 liters every 7000 km).'
The mileage is approximately 180,000 km.
Jens
Translated on 25-10-2026, 14:07.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Spark plug firing order Technical Data
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Valve: Causes, Symptoms & Cleaning Diesel Engine Technology
No new posts Vapor Deposits Intake Manifold: Causes & Solutions Diesel Engine Technology
No new posts Glow Plugs 1Z - Buy Online Now! Diesel Engine Technology
No new posts Glow Plugs for 1Z Models Diesel Engine Technology
