Pump Cable: Cheap Tuning for Your Pump
th3_fr34k
Post17-02-2005, 22:07    Subject: Pump Cable: Cheap Tuning for Your Pump Quote
hi,
I'm planning to do a '10-cent tuning' project soon with a friend who has electronics knowledge. It would be great if we could use the original connectors for the pump cable to make installation and removal easier.
Unfortunately, I can't find the connectors in the parts catalog. Could you provide me with a part number for my 1Z?
Translated on 19-10-2026, 19:43.
Post17-02-2005, 22:16    Subject: Pump Cable: Cheap Tuning for Your Pump Quote
Yes, the part number was posted here before. Try searching for "part number 10cent" or similar terms, and you should find something.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 19-10-2026, 19:44.
th3_fr34k
Post17-02-2005, 22:27    Subject: Pump Cable: Cheap Tuning for Your Pump Quote
I already did that, but unfortunately, I didn't find anything.
Karma: +807 / -0   Thank you, like it!
Post17-02-2005, 22:37    Subject: Pump Cable: Cheap Tuning for Your Pump Quote
Search function rocks...
/viewtopic.php?t=1583&highlight=parts*+*pump*
It is recommended to use wildcards to cover different spellings or terms.
Translated on 19-10-2026, 19:45.
No new posts Pump Cable Pin 8: Troubleshooting & Info Diesel Engine Technology
No new posts Pump Cables for 10C Tuning Diesel Engine Technology
No new posts VW MFD Rotary Knobs: Source & Buy Now Transmission, Chassis, Body & Interior
No new posts Motor Control Unit Connectors: Order Now! On-Board Diagnostics (OBD)
