ESP Tuning for VW AAB Engine
Pöbel
Post19-09-2004, 17:54    Subject: ESP Tuning for VW AAB Engine Quote
I bought a used AAB engine, and the adjustment screws are obviously completely misadjusted. Can anyone tell me how to correctly adjust the idle speed and residual fuel quantity? What is the function of the vacuum diaphragm on the pump? Does Bosch have any publications that can help me understand the pump?
With best regards in advance.
Mob.
Translated on 31-08-2026, 9:23.
TomyN
Post19-02-2005, 21:55    Subject: ESP Tuning for VW AAB Engine Quote
1. Idle mixture: This is the 'idle stop' of the carburetor. Turn the screw all the way out until the engine speed is constant. Then, turn it in until the engine speed increases, and then turn it back 1/2 a turn.
2. Idle Speed: Adjust using the 'vertical' screw on the 'engine side' of the ESP, either by feel or using a tachometer (which should read approximately 850 RPM).
Tomy.
Translated on 31-08-2026, 9:24.
Pöbel
Post20-02-2005, 9:49    Subject: SEO-Optimized German to English Translation Quote
@Tomy,
Thank you for your reply. In the meantime, I managed to fix it. I also had significant difficulties because the idle speed adjustment for the first engine was incorrect or not connected properly.
Mob.
Translated on 31-08-2026, 9:25.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BMM Motor - Pairing/Configuration of PD elements On-Board Diagnostics (OBD)
No new posts Adjusting a turbo-diesel engine Diesel Engine Technology
No new posts ESP Adjustment: 1.6 TDI Guide Diesel Engine Technology
No new posts p-box setup: How to configure your p-box Diesel Engine Technology
