qwert1
28-02-2005, 21:06 Subject: AFN Engine Glow Plug Fuse: What Size? |
hello,
Are there more than one fuse for the glow plug system in the AFN engine Golf 3? If so, where might they be located? I found an 80A fuse in the fuse box, on the top right, connected to a relay. Is it related to the glow plug system?
Translated on 30-09-2026, 21:43.
01-03-2005, 7:59 Subject: AFN Engine Glow Plug Fuse: How Much? |
qwert1 wrote: | | Are there more than one fuse for the glow plug system in AFN engines for Golf 3? If so, where could they be located? I found an 80A fuse in the fuse box, on the top right, behind a relay. Is it related to the glow plug system? |
The search would have helped you too.
Startprobleme-Fachartikel wrote: | The glow plug fuse often causes problems, and it is also well hidden in some vehicles: for example, in the 1997 Golf 3, it is located as an oversized flat fuse, poorly accessible on the top of the central electrical unit, while the owner's manual refers to the inner fender of the engine compartment.
In vehicles with a fuse box located on the battery, the glow plug fuse is usually located there. | Gruß Ulf
Translated on 30-09-2026, 21:44.
Profile PM Garage |
qwert1
01-03-2005, 16:37 Subject: AFN Engine Glow Plug Fuse: What Size? |
I also found that, but I just wanted to know if there were more than one.
Translated on 30-09-2026, 21:46.
Günther Guest
01-03-2005, 16:42 Subject: AFN Engine Glow Plug Fuse: What Size? |
I also found that, I just wanted to know if there was more than one!
best regards
If all the glow plugs receive their 12 volts, then no more fuses will blow.
Otherwise, the wiring in this area is so well-organized that...
Günther.
wolfi_b Profi-Schrauber
01-03-2005, 16:56 Subject: AFN Engine Glow Plug Fuse: What Size? |
What is the purpose of connecting multiple fuses in series? 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 30-09-2026, 21:47.
