kapernaum Guest
23-02-2005, 14:59 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Hello, fellow enthusiasts,
This was actually supposed to be a positive review about upgrading to 216mm nozzles, but things turned out differently. I'm really devastated...
I couldn't find anything comparable...
I replaced the nozzles last Saturday, everything went smoothly, it started working immediately, everything was sealed, everything was okay, and I was thrilled with the really impressive performance increase.
Then I drove another 50km, everything was fine.
On Sunday, I drove 150km on the highway, it ran perfectly with the new nozzles, no smoke, no problems, and according to the speedometer, it was going 205 (instead of 190 before).
Then, on Monday, I realized... I had a strange noise while hammering, I noticed a leak in the engine cover, compression leak on cylinder 2 (from the left). It was making a loud hissing sound and the cylinder head was messed up. I bought a new gasket, cleaned everything, and tightened the valve cover with 25 Nm.
It ran perfectly afterwards, but this morning I just opened the oil filler cap for fun, and now there's a strong overpressure (I think it's exhaust gases). The cap is bouncing when I let it lie down, and it's spraying a little oil.
The oil level is okay, and it didn't consume any oil during the drive.
It doesn't smoke or make any unusual noises.
On the out 'Puff' is a diesel oil film.
Coolant doesn't smell like exhaust fumes.
It seems to be running smoothly, and I don't see any performance loss.
I'm most worried about:
* Warped cylinder head gasket?
* Head warpage?
* Deformed head?
However, I only noticed the overpressure issue today by chance; I last tested it a few thousand kilometers ago...
Otherwise, the car (before the injector replacement) was running very well, the only problem was occasional fluctuations in the boost pressure at full throttle (ranging from 1.3 bar to 0.7 bar), but this has been happening more frequently lately.
I hope this information is helpful. I'm really devastated...
What do you think is going on with my car?
Best regards
23-02-2005, 15:51 Subject: Re: Catastrophe after fuel injector replacement (compression leak) |
kapernaum wrote: | | I started working on it in the morning, and while I was tightening the bolts, I heard a strange noise. I opened the hood, and I found a compression leak on cylinder 2 (from the left). It was making a horrible noise, and everything around the cylinder head was messed up. I bought a new gasket, cleaned everything, and tightened the injector sleeve with 25 Nm. |
"However, make sure all the nozzles are actually sealed, for example, by using engine oil, which you can inject with a syringe and cannula into the gap between the nozzle and the valve, and then check for bubbles while the engine is running.
The recommended torque of 25 Nm is, in my opinion, quite low. I had to apply significantly more torque when working on the AFN before no more bubbles appeared."
Quote: | | After that, it performed perfectly again, but this morning, just for fun, I opened the oil filler cap. Now there's a powerful overpressure (presumably exhaust gases), the cap is bouncing when I leave it on, and some oil is spraying out. |
In my opinion, there is still no reason to be alarmed.
The test with the blown-out leaf also yielded apparently alarming results at our ALH, with approximately 30,000 km on the odometer (the leaf almost reached the top of the hood), but otherwise the engine is in excellent condition (consumption, performance).
Head warpage?
Warped head? |
There are clearly more distinct symptoms (like water in the oil and vice versa, etc.). I would wait for those and not worry about it in the meantime (at least). Gruß Ulf
Profile PM Garage |
Georg-TDI Guest
23-02-2005, 16:04 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Translating... |
[Translating...]Fliegt der Deckel weg, oder hüpft er nur?
Wenn er im LL nur rumhüpft ist es normal, und dass da bisschen Öl rausspritzt ist auch kein großes Thema.
(meiner Erfahrung nach ist das ganze stark temperatur- und verschleißabhängig)
Alles ist Definitionssache, deshalb würde eine detaillierte Beschreibung uns weiter helfen.
Ansonsten ist dir der Düsentuning doch gut gelungen, oder?
Der AHU ist thermisch nicht für 216-Düsen ausgelegt, deshalb würde ich ihn langfristig nicht zu doll überfordern, sonst sind von dir angesprochene Schadensmerkmale nicht mehr weit!
EDIT: Ulf war mal wieder schneller
Gruß, Georg |
kapernaum Guest
23-02-2005, 16:22 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Translating... |
[Translating...]Hallo!
Danke für die Informationen /Ratschläge!
Mich hat heut morgen halt nur die nakte Panik ergriffen, da ich weiss, dass er früher mal (weiss nicht mehr so genau wann ich das letzte mal den Öldeckel bei laufenden Motor offen hatte) nicht so viel rausgeblasen hat... Da hatte ich das P in den Augen weil ich sofort auf solche unangenehmen Gedanken kam.
Dazu schreibe ich zur Zeit auch noch Diplomarbeit, das reduziert meinen Stress meine sofortige Panik nicht grade
Ich werde nachher mal genau prüfen wieviel er er rausbläst und mal Öl an die Düsenschäfte spritzen...
Die Düsentauschaktion an sich war wirklich kein Problem, ESP war sofort (mit lockeren Muttern) nach ca 3sek entlüftet und er lief auch mit Kompressionleck ganz normal (bis auf das leise Pfeiffgeräuch... |
kapernaum Guest
23-02-2005, 20:30 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Translating... |
[Translating...]Guten Abend,
da bin ich nochmal!
Also habe eben nochmal getestet (1x motor= ausgekühlt, 1x= Betriebstemp)
Also der Deckel hüpft nur ein wenig (hebt sich ca 0,5cm vom Ventildeckel (kalt wie warm), er 'tanzt' sozusagen auf dem Ventildeckel...
Der Gasaustoss ist gleichmässig von allen 4 Töpfen (soweit ich das beurteilöen konnte, aber nur von einem war es nicht)
Habe den Test mit einem DinA4 Blatt gemacht, an der Ventildeckeldichtung mit einem Finger festgehalten, es wird ca 10-15cm hochgeblasen (Blatt war danach kaum voll Ölspritzer, heute morgen war es viel extremer)
^^^Dieses Verhalten warm wie kalt.
Danke, für den Tip mit dem Öl am Düsensitz, Ulf!
Die Düse mit dem NHG blubbert am Zylinderkopfschaft minimal, ergo ziehe ich morgen nochmal den Düsenhalter um 30Grad nach, anonsten baue ich die auch nochmal aus, reinige den Düsensitz nochmal penibelst und dichte sie nochmal neu ab...Hätte ich diesen Trick schon vorher gehabt, hätte ich eine Nacht mehr ruhiger in meinem Leben schlafen können
Maschine springt direkt auf der ersten Kompression an, kein schütteln oder sonstiges
Ebenfalls kein Russ/Qualm/blaue oder weisse Fahne während des Kaltstarts und bei der Fahrt auch keine Sichtbare Fahne oder ähnliches...
Werde mal den Hoppeltest machen wegen der Kompression oder mal bei Bosch die Kompression messen lassen..
Bei denen war ich übrigens gestern zum Schraubennachziehen (mein Drehmomentschlüssel schlummert 150km weit weg in der Werkezugkiste) der Dieselmeister wollte mich zu einem Motoreninstandsetzer schicken, er meinte, der Kopf wäre hin, der Düsensitz müsste neu ausgebohrt werden (Ich wollte das nicht glauben, aber danach hatte ich trotzdem Panik)
Die Schalldämmung an der Motorhaube ist voll mit Öl und Russ, ich denke also das ich einige Zeit so gefahren bin (minimum 75km recht schnell auf der Bahn.)
..Aber die Leistung war da, wie gesagt er ging ab wie Schmitz Katze....
Nach euren beiden Statements bin ich wieder etwas beruhigter (sonst hätte ich diese Nacht wieder einen schlaflose)
Gruss |
23-02-2005, 20:47 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Translating... |
[Translating...] kapernaum wrote: | | Die Düse mit dem NHG blubbert am Zylinderkopfschaft minimal, ergo ziehe ich morgen nochmal den Düsenhalter um 30Grad nach, anonsten baue ich die auch nochmal aus, reinige den Düsensitz nochmal penibelst und dichte sie nochmal neu ab... |
Wisch mal das Montageloch im ZK mit einem Wattestäbchen o.ä. aus.
Bei längeren Undichtigkeiten könne Abgase offenbar kleine, mehr oder weniger radial verlaufende Kanäle ins Alu "schneiden", und man kriegt den Sitz ohne Nacharbeiten nie mehr ganz dicht.
Ich hatte mal so einem Fall und habe mir einen "Düsensitz-Schleifer" gebaut. Mit einem Stückchen Naßschleifpapier auf den rundgefeilten Schraubenkopf geklebt hab ich die eingeschnittenen Kanäle ausgeschliffen, bis sie nicht mehr zu erkennen waren (und mit einem schmalem Schraubenzieher beim vorsichtigen Drüberziehen auch keine "Hänger" mehr spürbar waren), und dann war die Düse auch bei normalen Anzugsmomenten wieder dicht . . .
@Rainer:
eigentlich wollte ich hier noch ein Foto meines "Werkzeuges" als Attachment reinstellen, aber das System sagt
Quote: | | Du hast deine maximale Upload Quota Grenze von 5 MB erreicht |
Könnte das evtl. an dem LDA-Foto-Fachartikel liegen?
Kann man die Grenze irgendwie nach oben verschieben? Gruß Ulf
Profile PM Garage |
Joined: 04/12/2002 Posts: 18099 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
23-02-2005, 21:08 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Translating... |
[Translating...] Hi Ulf,
eigentlich gibt es pro User gar keine Beschränkung, aber 5MB ist die maximalie Größe eines einzelnen Bildes.
Bild einfach als JPG/PNG in geringerer Auflösung nochmal probieren?
Ein raufsetzen der Grenzen macht IMHO keinen Sinn, stell Dir mal vor ein armer Tropf mit Modem will Dein Bild ansehen und wartet dann minutenlang bis irgendwas passiert...
Grüße, Rainer |
Profile PM WWW Garage |
23-02-2005, 21:14 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Translating... |
[Translating...] Rainer K. wrote: | | eigentlich gibt es pro User gar keine Beschränkung, aber 5MB ist die maximalie Größe eines einzelnen Bildes. |
Tja, eben hatte es ~ 270 kB, jetzt habe ich es auf 107 kB geschrumpft.
Und es geht trotzdem nicht -> die gleiche Fehlermeldung kommt nochmal
Edit: ich maile Dir mal das Bild, vielleicht kannst Du es ja einbauen.
Aber nicht laut lachen . . .
Edit 2: ich erinnere mich gerade, daß das Schmirgelleinen wohl doch eher ein Stückchen Naßschleifpapier war - aber fragt mich jetzt nicht mehr nach der Körnung  Gruß Ulf
MG4 Electric |
Profile PM Garage |
kapernaum Guest
23-02-2005, 21:27 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Translating... |
[Translating...]Da bin ich ja gespannt wie das Ulf'sche Schleifinstrument aussieht  |
24-02-2005, 7:14 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Translating... |
[Translating...] kapernaum wrote: | Da bin ich ja gespannt wie das Ulf'sche Schleifinstrument aussieht  |
Rainer hat es erstmal da geparkt:
MG4 Electric |
Profile PM Garage |
wolfi_b Profi-Schrauber
24-02-2005, 9:56 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Translating... |
[Translating...] Und was hast du mit dem Schleifstaub gemacht? 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV |
kapernaum Guest
24-02-2005, 13:08 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Translating... |
[Translating...]Hallo Ulf,
das sieht wirklich sehr interessant aus!
1) Wie hast du denn das Schmiergelpapier (Leinen) an der Schraubenspitze befestigt?
2) Da ich mich gleich mal um die 2.lockere Düse kümmern wollte, wollte ich mal fragen, ob du noch einen Geheimtip hast, wie man den Düsenstock möglichst grade in der Halterung arretiert-ausrichtet...
Gruss |
24-02-2005, 19:17 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Translating... |
[Translating...] kapernaum wrote: | | 1) Wie hast du denn das Schmiergelpapier (Leinen) an der Schraubenspitze befestigt? |
Mit hundsgewöhnlichem Pattex
Quote: | | 2) Da ich mich gleich mal um die 2.lockere Düse kümmern wollte, wollte ich mal fragen, ob du noch einen Geheimtip hast, wie man den Düsenstock möglichst grade in der Halterung arretiert-ausrichtet... |
Dünnes Klebeband um die Düse wickeln, in der Höhe der Loch-Oberkante des ZK.
Und zwar soviel, daß die Düse grade "saugend" in das Loch paßt.
Quote: | | Und was hast du mit dem Schleifstaub gemacht? |
Mit einem öligen Lappenstück um einen dünnen Schraubenzieher rausgewischt.
Die evtl. paar weichen Alustäubkörnchen im Motor haben mich nicht weiter gekratzt. Und den AFN auch nicht, er lief genauso wie vorher . . . Gruß Ulf
MG4 Electric |
Profile PM Garage |
Albrecht Profi-Schrauber
Joined: 05/12/2002 Posts: 284 Karma: +10 / -0 Location: DD
24-02-2005, 21:06 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Translating... |
[Translating...] Leute Leute,
eh ich den Dreck gemütlich in den Motor rieseln lasse und Zylinder und Turbo sandstrahle, würde ich lieber ein paar Kilometer fahren bis der Ruß alles schön von alleine abgedichtet hat
Zum blow by am Ventildeckel: Jeder Motor (auch ein gut eingelaufener) produziert blow by Gase. Die angesprochenen Messmethoden haben NULL Aussagekraft. Warum die Aufregung wenn das Auto gut anspringt und auch sonst alles normal ist? Wenn ein Kolben durch ist merkt man das garantiert auch anders
mfG
Albrecht 01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg. |
24-02-2005, 21:24 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Translating... |
[Translating...] Albrecht wrote: | eh ich den Dreck gemütlich in den Motor rieseln lasse und Zylinder und Turbo sandstrahle, würde ich lieber ein paar Kilometer fahren bis der Ruß alles schön von alleine abgedichtet hat |
Tsts . . . Alustaub von ~ 600er Schleifpapier hat für mich bei weitem noch keine Sandstrahl-Qualitäten.
Und wenn Ruß einen Düsensitz fein-abdichten würde, hätten bei mir bei der Ölprobe mehrere 100 km nach dem Düsentausch keine Bläschen mehr hochkommen dürfen . . . Gruß Ulf
MG4 Electric |
Profile PM Garage |
kapernaum Guest
24-02-2005, 22:46 Subject: Catastrophic failure after replacing the fuel injectors (due to a compression leak) |
Translating... |
[Translating...]Guten Abend!
So,wollte mich nur noch mal kurz zurückgemeldet haben. Habe heute die Düse mit dem NHG nochmal ausgebauta, alles blitzeblank gemacht und mit neuen Dichtring einbebaut, alles dicht. Die alten kupferdichtringe sahen übrigens recht interessant aus durch die Lecks, sie waren nach weniger als 200km bereits deutlich-rot-gelb oxidiert und angefressen(von der Farbe her sah es nach Schwefel aus) Nach mehren Tests mit aufgesprühten Öl auf die Dichtfläche scheint alles dich zu sein  Ich denke nicht, dass der Motor irgendwelche Schäden davongetragen hat... (Bis darauf das er nun so ölig ist wie ein alter Schiffsdiesel  )
*Klopf auf Holz*
Werde ich jetzt genau im Auge behalten...
Noch mal vielen Dank für die guten Ratschläge, echt Klasse!
In ein paar hundert km werde ich mal einen ausführlichen Düsentausch-Erfahrungsbericht im AHU posten...
Wenn mein Laptop nun noch will werde ich den Leerlauf um ca 40rpm runterregeln und dann demnächst mal mit VAG Com meine Luft und Einspritzwerte loggen wegen meinem Ladedruckprpblem...
Viele Grüsse
P.S. Ich habe nur die Düsenköpfe gewechselt, dh. die Öffnungsdrücke haben sich nicht verändert. Muss ich mit den grossen Düsen den Einspritzbeginn irgendwie vorverlagern (wegen dem nun gleichzeitigen Treibstoff-Mehrvolumen im Zylinder)?Kann man mit einer Vorlverlegung die Verbrennung vielleicht etwas 'sanfter' ablaufen lassen?? (Sorry, kann mich nicht fachmännischer ausdrücken) |
