Audi A4 Serpentine Belt Tensioner Failure (Solution)
Post10-03-2005, 14:13    Subject: Audi A4 Serpentine Belt Tensioner Failure Quote
Author: Michael II.
Serpentine belt tensioner broken, serpentine belt torn.
Up to chassis number 8DWA 237111.
Cause:
Lack of free play on the generator pulley can lead to overloading of the V-ribbed belt drive. As a result, the V-ribbed belt tensioner may break, and/or the V-ribbed belt may tear.
Solution:
Replace the serpentine belt tensioner and the serpentine belt.
It is essential to replace the fixed pulley on the generator with a freewheeling pulley. Freewheeling pulley for Bosch generator No. 028 903 119 T.
Friction wheel for Valeo alternator No. 028 903 119 AC.
Make sure to install spacer ring No. 028 903 237 A between the freewheel pulley and the generator, otherwise the belt will be damaged.
Please provide the German text you would like me to translate.
Bye.
Michael.
Translated on 30-08-2026, 20:41.
Ratings - Audi A4 Serpentine Belt Tensioner Failure
No new posts Document A2 8Z0 MJ 2003, broken rear spoiler Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken Exhaust on VW Transporter 7DK2H2 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt component, notched belt, broken. Cause? Diesel Engine Technology
No new posts Serpentine belt is worn out Diesel Engine Technology
No new posts T6 TDI, squealing ribbed belt, TPI Diesel Engine Technology
No new posts V-belt solved!!! Diesel Engine Technology
