Audi A4 documentation: Oil leak at the oil cooler (Solution)
Post10-03-2005, 14:14    Subject: Audi A4 documentation: Oil leak at the oil cooler Quote
Author: Michael II
Oil leak at the oil cooler.
Cause:
When replacing the oil filter, there is a risk of twisting the oil cooler, which can lead to a leak between the oil cooler and its bracket.
Solution:
The O-ring can be ordered as a replacement part under the number 028 117 070B. Please only replace the O-ring; the oil cooler is not defective.
Please provide the German text you would like me to translate into English. I will then give you only the translation, without any explanations.
Bye.
Michael.
Translated on 13-07-2026, 18:01.
Ratings - Audi A4 documentation: Oil leak at the oil cooler
No new posts ATF oil leak on 74 kW TDI engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Leak MKB AKF: Oil Level Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Leak Motor Block: AFB & AKN Engine Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BKC Engine Oil Cooler: Buy Now! Diesel Engine Technology
No new posts Leaky Oil Cooler: What to Do? Diesel Engine Technology
No new posts Oil Cooler Upgrade for ALH Engine Problems Diesel Engine Technology
No new posts TDI AWX Oil Leak: Causes and Solutions Diesel Engine Technology
