MKB & MSG Error Codes: Troubleshooting Guide (Solution)
Karma: +807 / -0   Thank you, like it!
Post10-03-2005, 14:25    Subject: MKB & MSG Error Codes: Troubleshooting Guide Quote
Author: Michael II.
1.6 L / 1.8 L / 2.0 L with 74, 75, 85, 92, and 110 kW.
The check engine light is illuminated due to detected misfires (error codes: 16684, 16685, 16686, 16687, 16688).
Cause:
The imbalance in the serpentine belt is transferred to the crankshaft and is detected by the engine control unit as a misfire.
Solution:
If the described fault is present, but no misfires are detected during driving, check whether there is excessive pulsating movement of the serpentine belt tensioner.
If so, the ribbed belt needs to be replaced. Since only ribbed belts from the company Gates are affected, ribbed belts from the company MBL can be ordered as an alternative.
Please provide the German text you would like me to translate.
Bye.
Michael.
Translated on 22-09-2026, 4:55.
Ratings - MKB & MSG Error Codes: Troubleshooting Guide
No new posts Documentation of driving behavior deficiencies, various v... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Various Driving Behavior Defects Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Camshaft Bolt Service: PD Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Various error codes Gasoline Engine Technology
No new posts EGR Valve for 2.0L TDI Engines Diesel Engine Technology
No new posts Search logs with MWB 8+10, various MKBs. On-Board Diagnostics (OBD)
No new posts 32B-JX: Questions and Answers Diesel Engine Technology
