Spark Plug Ignition Coils: Troubleshooting Guide (Solution)
Post10-03-2005, 14:29    Subject: Spark Plug Ignition Coils: Troubleshooting Guide Quote
Author: Michael II
Misfires, starting problems, unstable idle, hesitation, and acceleration lag.
Cause:
Manufacturing problems with the spark plug ignition coil.
Insulation problems in the engine pre-wiring harness for 1.8L turbo engines.
Solution:
To avoid repeat repairs and potential damage to the ignition coils, in the event of a repair, only the specified special tools T10094, T10095A, and T40039 should be used for assembly and disassembly.
The coil must only be removed in the longitudinal direction of the ignition coil. If a coil is stuck, do not attempt to remove it by twisting.
Different procedures are required for replacing the spark plugs on different models.
Phaeton:
In the event of a complaint, all spark coil igniters must be replaced in all Phaeton models.
1.8L Turbo:
For vehicles with 1.8L turbo engines from the 2001 and 2002 model years, replace the defective ignition coil packs and all coil packs that do not already have the index J or L.
Check the insulation of the wires leading to the ignition coils on the cylinder head for cracks. If cracks are present in the insulation, the engine pre-wiring harness must be repaired using repair harness number 1J0 971 658 M.
Other vehicle models:
For the remaining vehicle models, the established procedure remains in place: In the event of the first reported issue, only the defective spark plugs and ignition coils will be replaced. However, in cases of repeated issues, to avoid further modifications to the vehicle, all spark plugs and ignition coils will be replaced.
Please provide the text you would like me to translate from German to English.
Bye.
Michael.
Translated on 18-10-2026, 4:10.
Ratings - Spark Plug Ignition Coils: Troubleshooting Guide
No new posts Document: Gasoline Engines, Audi, Model Year 2001, Combus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Mass Sensor: Readings for Gasoline Engines General Tips
No new posts Document MKB AKQ, defective timing belt tensioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF: What's wrong with it? Upload
No new posts LMM failure? On-Board Diagnostics (OBD)
No new posts MFA malfunction On-Board Diagnostics (OBD)
No new posts MKB: ARL PDE failure? Upload
