1Z NHG: Numbering Errors in German Inheritance Law
Post11-03-2005, 19:15    Subject: 1Z NHG: Numbering Errors in German Inheritance Law Quote
Hi.
What do you think the nozzle with the needle movement sensor is called in the 1Z?
I was thinking of the license plate 028 130 201 JX.
But just now I read something about 028 130 201 GX.
What do you say?
Do the electrical connectors of the ASV nozzles fit the 1Z engine?
Translated on 26-10-2026, 11:56.
wolfi_b
Post13-03-2005, 8:42    Subject: 1Z NHG: Numbering Errors in German Inheritance Law Quote
Hi Martin!
If I remember correctly:
028 130 201 H is for 1Z in Audi 80/A4/A6.
028 130 201 J is responsible for the remaining 1Z.
Source: http://www.bosch-automotive.com/ecat-online
I suspect the cable length or the connector might be different. If you can post the length and a picture of the connector, I can compare it to my 028 130 201 H.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 26-10-2026, 11:57.
mullemaus
Post13-03-2005, 10:00    Subject: 1Z NHG: Numbering Errors in German Inheritance Law Quote
028 130 201 G or GX.
Installed in the Audi 80/90 and Cabrio models of the A4 and A6, in the Caddy and Golf (Cabrio, Ecomatik) models, in the Passat, Sharan, and Bora.
The 028 130 201 G or GX is not an NHG injector icon_wink.gif, but a standard one.
028 130 201 JX = NHG injector icon_wink.gif (194€). Suitable for engine codes 1Z in vehicles with AHU and AFF engines.
Translated on 26-10-2026, 11:58.
Post13-03-2005, 10:28    Subject: 1Z NHG: Numbering Errors in German Inheritance Law Quote
I messed something up!
The question is, H and J.
I only have J-type nozzles for my NBF system, but I've now been offered H-type nozzles.
The ecat also says J.
Sorry, could you please answer again icon_smile.gif?
"Thank you."
m,
Translated on 26-10-2026, 11:59.
mullemaus
Post13-03-2005, 11:09    Subject: 1Z NHG: Numbering Errors in German Inheritance Law Quote
Of course, we can answer icon_wink.gif.
The H or HX (exchange unit, €194) was used in the Audi 80/90 and Cabrio models. The engine code for this is 1Z. Therefore, it should fit. It was installed from chassis number 8C-P-059 001 onwards. Before that, the part number was 028 130 201 AX (€185) up to chassis number 8C-P-059 000.
Have fun with the new nozzle icon_smile.gif.
Translated on 26-10-2026, 12:01.
wolfi_b
Post14-03-2005, 7:37    Subject: 1Z NHG: Numbering Errors in German Inheritance Law Quote
I completely messed it up exactly like that icon_lol.gif.
But what I wrote above is still correct (with the corrected part number)!
1993 Audi 80 B4 1Z
No new posts Injector ET Numbers: Find Yours Now! Diesel Engine Technology
No new posts Different engine part numbers - what does each one mean? Diesel Engine Technology
No new posts Engine Control Unit (ECU) Numbers: Meaning & Explanation Diesel Engine Technology
No new posts VAG Injector Pump Part Numbers for 1Z Models Diesel Engine Technology
