BlauBaer Guest
05-11-2005, 19:58 Subject: STG Golf III AFN: No Boost Sensor Connection? |
hello,
Does anyone know if there was a version of the engine control unit (ECU) that didn't have a connection for the boost pressure sensor?
I found one on e***, but the seller doesn't have the connector for my specific control unit. I can't imagine how it's supposed to work otherwise.
The engine control unit (ECU) is supposed to be from a Volkswagen Golf III AFN with the part number 028 906 021 GH or JG. Based on its appearance, it's an MSA15 (it looks exactly like mine).
I'm asking because I want to buy a new one. I already have one with the number 028 906 021 DF, and it's for a VW. A GH or JG would also fit, but it's strange if they don't have a connector.
best regards, BB
Translated on 10-10-2026, 3:08.
05-11-2005, 21:46 Subject: STG Golf III AFN: No Boost Sensor Connection? |
My information on this is:
Some AFNs (Air Flow Nozzles) have a pressure sensor in the intake manifold.
However, these are devices from the Passat 3B.
Translated on 10-10-2026, 3:09.
Profile PM Garage |
08-11-2005, 12:10 Subject: STG Golf III AFN: No Boost Sensor? |
BlauBaer wrote: | | STG soll aus einem Golf III AFN sein mit der nummer 028 906 021 GH od. JG. |
In the G3, I had the 021GH, definitely with a hose nipple.
Translated on 10-10-2026, 3:10.
Profile PM Garage |
Rudi Guest
08-11-2005, 12:32 Subject: STG Golf III AFN: No Boost Sensor Connection? |
G3 TDI engines (AHU, AFN and all newer 1Z models) use an MSA15.5 control unit with a 68-pin connector.
integrated charge pressure sensor and integrated altitude sensor.
Part number format: 028 906 021 xx.
Later (e.g., in the A3), there was the MSA15.7 with a split connector and without a boost pressure sensor.
(as Martin already mentioned).
Part number format: 038 906 018 xx.
Rudi
Translated on 10-10-2026, 3:11.
BlauBaer Guest
08-11-2005, 18:47 Subject: STG Golf III AFN: No Boost Sensor Connection? |
I'm just going to post the link so you can see for yourselves what I'm talking about.
If this is prohibited, I would like to apologize in advance and request that an administrator delete the link.
best regards
http://cgi.ebay.de/Motorsteuergeraet-Steuergeraet-VW-TDI-110-Golf-III-3-AFN_W0QQitemZ4587187851QQcategoryZ61544QQrdZ1QQcmdZViewItem
Translated on 10-10-2026, 3:12.
Rudi Guest
08-11-2005, 20:29 Subject: STG Golf III AFN: No Boost Sensor Connection? |
The picture seems quite clear...
The handwritten numbers would also belong to a Golf 3 AFN.
But - even with the latest G3 models (Variant and Cabrio - year '99), the G71 was...
integrated into the control unit; so it should have that connection!
The only MSA15.5 drives I know of that don't have this connector are those from the SDIs (e.g., 021FJ).
Whatever is being offered in the auction, I would stay away from it.
The price isn't exactly a bargain either.
Rudi
Translated on 10-10-2026, 3:13.
Julian Guest
08-11-2005, 20:42 Subject: STG Golf III AFN: No Boost Sensor Connection? |
Translating... |
[Translating...]Test
Rudi Guest
08-11-2005, 20:45 Subject: STG Golf III AFN: No Boost Sensor Connection? |
Hello Julian
Translated on 10-10-2026, 3:14.
Thomas Profi-Schrauber
Joined: 04/17/2002 Posts: 329 Karma: +2 / -0 Location: Darmstadt
10-11-2005, 13:33 Subject: STG Golf III AFN: No Boost Sensor Connection? |
Quote: | | The only MSA15.5 drives that I know of without this connector come from the SDIs (e.g., 021FJ). |
I would have said the same thing. AFN engine control units are simply more expensive than those from Sauger.
Greetings,
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 10-10-2026, 3:15.
