26-04-2005, 17:07 Subject: Input parameters for Russian character recognition |
What input parameters does the characteristic curve (specifically for the 1Z) depend on?
I'm experiencing a situation where the actual air mass is double the expected value (compared to the target value) at 1300 RPM, but the boost control valve is closed. Should be 2xx mg / Is 5xx mg.
When using a diode (which is permanently set to 847.9 mg), the Russian border is above the torque limit.
I can provide more detailed logs if you would like.
How is the turbo supposed to generate boost if it doesn't have anything to work with?
Profile PM Garage |
Rudi Guest
26-04-2005, 19:10 Subject: Input parameters for Russian character recognition |
Hi Martin,
The field contains the permissible injection amount [mg].
The axes are speed (RPM) and air mass [mg].
Rudi
:edit:
Sure, here's the translation:
:edit:
Here's a picture showing the relevant area from the blurring and...
Torque limitation.
| Description: |
| File size: |
70.88 KB |
| Viewed: |
785 times |
26-04-2005, 21:30 Subject: Input parameters for Russian character recognition |
Great, thanks, that seems to fit pretty well with the values I logged.
| Description: |
| File size: |
19.89 KB |
| Viewed: |
716 times |
| Description: |
| File size: |
32.92 KB |
| Viewed: |
714 times |
Profile PM Garage |
