Input parameters for Russian character recognition
Post26-04-2005, 16:07    Subject: Input parameters for Russian character recognition Quote
What input parameters does the characteristic curve (specifically for the 1Z) depend on?
I'm experiencing a situation where the actual air mass is double the expected value (compared to the target value) at 1300 RPM, but the boost control valve is closed. Should be 2xx mg / Is 5xx mg.
When using a diode (which is permanently set to 847.9 mg), the Russian border is above the torque limit.
I can provide more detailed logs if you would like.
How is the turbo supposed to generate boost if it doesn't have anything to work with?
Rudi
Post26-04-2005, 18:10    Subject: Input parameters for Russian character recognition Quote
Hi Martin,
The field contains the permissible injection amount [mg].
The axes are speed (RPM) and air mass [mg].
Rudi
:edit:
Sure, here's the translation:
:edit:
Here's a picture showing the relevant area from the blurring and...
Torque limitation.
 File size:  70.88 KB
 Viewed:  795 times
Post26-04-2005, 20:30    Subject: Input parameters for Russian character recognition Quote
Great, thanks, that seems to fit pretty well with the values I logged.
 File size:  19.89 KB
 Viewed:  728 times
 File size:  32.92 KB
 Viewed:  722 times
No new posts Russian Field 1Z: ASV and ASZ Explained On-Board Diagnostics (OBD)
No new posts BLS Label File: Guide & Download On-Board Diagnostics (OBD)
No new posts Fuel injectors for 130 PD? Diesel Engine Technology
No new posts ESD Spacer Washers: Secure & Protect Diesel Engine Technology
