christians Profi-Schrauber
07-04-2003, 20:15 Subject: Fuel Injectors Part Numbers AAT |
"Does anyone know the part numbers for the injectors used in the AAT engine? Are injectors from comparable 4-cylinder engines, specifically the 1Z engine, compatible with the AAT?"
Gruß Christian
Translated on 28-10-2026, 12:46.
DocSnydor Guest
08-04-2003, 7:15 Subject: Fuel Injectors Part Numbers AAT |
I have 2 numbers related to the AAT.
046 130 201 EX
046 130 201 EV
and for the nozzle, use NBF.
046 130 202 EX
046 130 202 EV
Unfortunately, I can't tell you what the difference is. They are both from AAT.
Here is the information from 1Z:
028 130 201 G (or GX or GV)
028 130 201 J (the nozzle with NBF, also JV or JX)
David.
Translated on 28-10-2026, 12:47.
08-04-2003, 11:38 Subject: Fuel Injectors Part Numbers AAT |
Thank you.
Gruß Christian
Translated on 28-10-2026, 12:48.
DirkC4 Blaumann
26-05-2003, 10:37 Subject: Fuel Injectors Part Numbers AAT |
The parts marked with "X" are replacement parts.
The "V" replacement parts...
Are there any alternatives available from third-party manufacturers, not from VAG or Bosch?
Andi aus dem Ösiland Guest
18-05-2005, 14:22 Subject: Fuel Injectors Part Numbers AAT |
Hello!
Does anyone know if the injectors mentioned above are for the AAT engine in a 100 or an A6?
Greetings,
Andi.
Translated on 28-10-2026, 12:49.
Kristian Blaumann
Joined: 09/30/2004 Posts: 43 Karma: +2 / -0 Location: Nähe Braunschweig
18-05-2005, 19:24 Subject: Fuel Injectors Part Numbers AAT |
201 = Standard nozzle
202 = Nozzle with N
AAT models 91 to 94 ==> 046 130 201 BX and 046 130 202 A or AX.
AAT 94 to 97 ==> 046 130 201 E or EX and 046 130 202 E or EX
ABP 91 to 92 ==> 046 130 201 X and 046 130 202 X
AEL 94 to 97 ==> 046 130 201 F or FX and 046 130 202 FX
Sometimes, the letters "V" and "H" are still used as suffixes (e.g., 046 130 201 EV).
Complete injector assemblies are available from Bosch and Beru and can be found as accessories under the category "injector housings" or "injector manifolds." (There are reportedly two other suppliers, but I haven't been able to find them yet.)
Hi Krissi.
96´er A6 Avant 2,5 TDI 140@170PS AEL-Motor
zZ Probleme wenig Leistung+hoher Verbrauch trotz aller neu eingebauten Teile => ca 11T€+5T€ für neuen motor+ neues getriebe 1,5T€ = 17,5T€
wär Rächdschraippfäler viendedt, darpf sie behalden
Translated on 28-10-2026, 12:51.
18-05-2005, 21:51 Subject: Fuel Injectors Part Numbers AAT |
You're very welcome!
So, I'm going to install the AAT injectors from the A6 into my A4 (I got all of them new for €230 each). Let's see if there's any change in the soot behavior or if I can get a little more power due to better atomization. The AAT injectors in the A6 can be tuned up to 153 hp, while the ones in the A4 are only tuned to 140 hp (but it could also be due to a different impeller in the ESP and/or different pistons)!
Andi.
Translated on 28-10-2026, 12:53.
Trecker Treiber Guest
19-05-2005, 20:49 Subject: Fuel Injectors Part Numbers AAT |
@ Andi from Austria.
Oh, you snatched the fuel injectors from me on eBay,  ?
20-05-2005, 7:14 Subject: Fuel Injectors Part Numbers AAT |
Could you check again? Are there any more available (from the same provider)?
I couldn't believe at first that it was all 5, but it is  .
Andi.
Translated on 28-10-2026, 12:54.
