Installing a 2.0 DITD engine from a Mazda 626 into a 323F.
konjoy
Post12-06-2005, 14:29    Subject: Installing a 2.0 DITD engine from a Mazda 626 into a 323F. Quote
I drive a Mazda 323f from 1999 with a 2.0 ditd engine producing 90 horsepower. I've received a good offer for a 2.0 ditd engine from a Mazda 626 with 110 horsepower. The differences are similar to those between a 1Z TDI and an AFN TDI. My engine has a wastegate turbo, while the 110 horsepower engine has a variable geometry turbo (VTG). The engine I'm offered comes with all the attachments, but without the engine control unit (ECU). Does anyone know if it's possible to use this engine with my existing ECU, or will there be problems due to the different turbo types?
Translated on 07-07-2026, 21:39.
No new posts Installing a DAB/DAB+ antenna General Tips
No new posts Installation instructions for a Calix immersion heater Troubleshooting & Guides
No new posts AGR beim Mazda 323F DITD lahmlegen Diesel Engine Technology
This topic is locked, you cannot edit or reply. Mazda 626 DITD - Starting Problems Diesel Engine Technology
No new posts Install AHF in AFN Vehicle? Diesel Engine Technology
No new posts Lambdasonde universal verbauen und anschließen ? Gasoline Engine Technology
