Madness wrote: |
| I think that your switch is no longer making contact. |
I doubt that, because the driver's side mirror, passenger side mirror, and rear window defroster should all be connected to the same wire behind the switch.
I suspect you have a broken wire, which is causing the driver's side mirror to heat up continuously. A likely culprit would be the wiring harness that runs to the driver's door. Take a look inside there.
Guste.
