Evening everyone,
I would like to ask for your help again.
After repeatedly encountering speed readings on my way home...
Of the things I've logged and compared here in this forum, I'm actually only...
eines im Messwerteblock 001 (Einspritzmenge) aufgefallen. As I once was...
While idly browsing through the control modules of a car's computer system using VAG-COM in a parking lot...
A regulation voltage of 1.91 volts and a quantity of 8.8 mg.
displayed. Now, in the repair manual, Volkswagen states that the pump is too lean, which...
It might also be related to the performance; there's a slight haze in the reflection at gears 1 and 2.
and nothing happens after the fourth gear. I'd also like to add that the pump is new.
and the basic settings are correct (using VAG-COM). Now I would like to ask if anyone...
das schon mal gehabt hat bzw. von was es kommen könnte. Should I...?
I haven't read the article about it, so please excuse me
Here are some other things that have been done.
- AGR deactivated (plate).
- temporarily installed a pre-pump.
- Kat is checking.
- Boost pressure not measured with VAG COM (1.2 bar).
Thank you in advance.
Audi
