Increase Printer Pressure: How-To Guide
Go to page: 1, 2  Next
Animalking
Post26-08-2002, 18:50    Subject: Increase Printer Pressure: How-To Guide Quote
I have the following scenario!
A larger intercooler was installed on the A3 130 PS TDI PD.
This larger intercooler causes a pressure drop because it has a larger resonant chamber than the previous one (larger intercooler).
Now, in this thread, I discovered https://community.dieselschrauber.org/en/viewtopic.php?t=562&highlight=pin+belegung that you can modify the output signals at the boost pressure sensor (4-pin)!!!
Is it possible to simulate a lower boost pressure by connecting a resistor in series with the boost pressure signal?
This could increase the boost pressure, or...?
It's not directly about tuning, but rather about reducing the pressure drop caused by the larger intercooler! The goal is simply to achieve a slight and inexpensive increase in boost pressure!
Thank you for your help.
Translated on 25-10-2026, 4:43.
Post26-08-2002, 19:25    Subject: Boost Turbo Pressure: How To Increase It Quote
Hi.
Using a resistor in this setup can be a bit unreliable.
I would insert a diode into the charge pressure signal line; this practically always reduces the signal by about 0.5 volts and doesn't pose any problems regarding adaptation to the surrounding impedance level.
If the increase in charging pressure is too high, you can still connect a resistor in parallel with the diode and experiment to find the (kilo)ohm value that results in the desired pressure increase.
Translated on 25-10-2026, 4:44.
Animalking
Post26-08-2002, 19:34    Subject: Increase Printer Pressure: How-To Guide Quote
Are there different types of diodes with varying voltage ratings?
By how much does the pressure increase if the signal decreases by approximately 0.5 volts?
Translated on 25-10-2026, 4:45.
Post26-08-2002, 19:46    Subject: Diodes: Types, Applications & How They Work Quote
By how much bar does the pressure increase when the signal decreases by approximately 0.5 volts?
Hi.
Common silicon general-purpose diodes, such as the 1N4148, all have a forward voltage drop of approximately 0.5 volts.
Special types, such as Schottky diodes, typically provide less voltage, usually around 0.3 volts, as far as I know.
A decrease in signal voltage of 0.5 volts can already result in 0.2 or 0.3 bar more pressure - but this is just a rough estimate icon_sad.gif. It is best to try it with LDA on board.
Translated on 25-10-2026, 4:46.
Georg_G
2012 Volkswagen Golf
Post26-08-2002, 23:12    Subject: Increase Printer Pressure: How-To Guide Quote
Whether a larger intercooler was installed or not, shouldn't the engine control unit (ECU) regulate the pressure to a constant level, aside from the initial oscillation behavior of the pressure waves? Or have I misunderstood something?
Georg.
Translated on 25-10-2026, 4:48.
Mtw13ve
Post26-08-2002, 23:14    Subject: Increase Printer Pressure: How-To Guide Quote
I agree.
You could adjust your VGT (Variable Geometry Turbine) setting. This would cause the turbo to build boost pressure earlier. Am I right about that? It's because the impeller is set to a 'fat' position. This would generate pressure more quickly. Even if it then adjusts itself.
'cu' is a Spanish abbreviation for 'con usted,' which means 'with you.' It is often used in online communication to indicate that the sender is available to chat or talk.
Here is an example of how 'cu' might be used in a conversation:
Person A: 'Hey, I'm bored. Want to chat?'
Person B: 'Cu!'
This means that Person B is available to chat with Person A.
'Cu' can also be used to indicate that the sender is thinking about the recipient. For example, if Person A sends a message to Person B and then receives a reply that says 'cu,' it could mean that Person B is thinking about Person A and wants to connect with them.
Overall, 'cu' is a versatile abbreviation that can be used in a variety of ways. It is a common way to indicate availability, interest, or affection in online communication.
Translated on 25-10-2026, 4:49.
Georg_G
Post26-08-2002, 23:25    Subject: Increase Printer Pressure: How-To Guide Quote
That idea about using VTG rods might actually be a good one.
Ultimately, this is a regulation element that directly affects the oscillation behavior of this system. However, things can go completely wrong, especially if an LDA (Linear Displacement Actuator) is not installed. It could potentially cause such extreme oscillations that either a) the turbocharger stops working, or b) only a pressure-carrying hose bursts.
What kind of turbocharger is in the 130 PD model? Is there perhaps a performance chart showing pressure, speed, and flow rate? That would be very interesting.
Best regards, Georg.
Translated on 25-10-2026, 4:50.
Animalking
Post26-08-2002, 23:33    Subject: Increase Printer Pressure: How-To Guide Quote
Hello.
I believe the 130 PD model has the Garrett 17 turbocharger.
How can the VTG (Variable Turbine Geometry) of the turbocharger be adjusted?
Unfortunately, I don't have a pressure-time diagram. However, it would be interesting to know how many bar (absolute) the charger can withstand? If the pressure is too high, the charger could overspin and break!
P.S.: An LDA (Laser Doppler Anemometer) is installed!!!
Translated on 25-10-2026, 4:51.
Mtw13ve
Post27-08-2002, 0:11    Subject: Increase Printer Pressure: How-To Guide Quote
It's a VNT-17. There are no diagrams available for it. I've already asked and searched everywhere. Even Garrett won't release any. The turbocharger can handle a boost pressure of around 1.5 bar.
I wouldn't turn the VGT more than 1/2 to 1 rotation!
The right direction will quickly become clear!
To adjust it, you need to twist the screw that's on the shaft of the VTG using pliers. Please don't ask me which direction to turn it. Also, that screw is secured with Loctite, so you might need to reapply it afterward. You never know!
cu
chris
Translated on 25-10-2026, 4:53.
Animalking
Post27-08-2002, 0:28    Subject: Increase Printer Pressure: How-To Guide Quote
Thank you for the information!!!
I need to find that screw!
Can we get there without having to build anything?
Do you happen to have any idea how much boost the 100 HP PD TDI turbo can handle? Is it a Garrett VNT 15?
Translated on 25-10-2026, 4:54.
Mtw13ve
Post27-08-2002, 1:31    Subject: Increase Printer Pressure: How-To Guide Quote
I think that's a VNT-15. Unfortunately, I don't know the boost pressure. But with the VNT-15, things get pretty intense starting at around 1.2 bar. It depends on how you drive. But I don't need to tell you that, do I? You probably can't sleep anyway, lol.
TDI 180
Post27-08-2002, 9:54    Subject: Increase Printer Pressure: How-To Guide Quote
Hello Animalking and Mtw13ve!
Here's a question for you all.
Was für einen Turbo hat der 150 PD eigentlich ? Und wieviel bar schaft das Ding max ? Also Garret too?
Sure, here's the translation:
'Thank you in advance!'
Translated on 25-10-2026, 4:55.
Mtw13ve
Post27-08-2002, 11:20    Subject: Increase Printer Pressure: How-To Guide Quote
'Yes, it's a Garrett turbo. But why do you want to know? It won't fit in your car anyway. It's a VNT-20 turbo, and it definitely produces 1.5 bar of boost. As far as I know, that's the standard boost pressure. 1.8 bar should actually be achievable.'
You should know that the larger the turbo, the bigger the turbo lag!
Therefore, if you want to buy another turbo, get a VNT-17 turbo. If you're lucky, it might even fit directly onto your old manifold. If not, the people at www.centralvwaudi.com will probably be able to make a suitable manifold for you.
Person B: 'Cu!'
Translated on 25-10-2026, 4:57.
Animalking
Post27-08-2002, 12:01    Subject: Increase Printer Pressure: How-To Guide Quote
Hehe, I actually drive a 100 hp TDI PD engine that's been chipped!
He now has approximately 1.25 bar!!! I probably shouldn't solder a diode in there, or I'll likely have to look for a new turbo!!! I would also prefer a 150 HP TDI. icon_cool.gif
Translated on 25-10-2026, 4:58.
Achim
Post27-08-2002, 12:38    Subject: Increase Printer Pressure: How-To Guide Quote
I've also been thinking about increasing the boost pressure.
I wanted to try that using a voltage divider (potentiometer) and an impedance converter.
(due to signal interference) try.
What do you think about it?
Translated on 25-10-2026, 4:59.
TDI 180
Post27-08-2002, 13:13    Subject: That Fits Me Well! Quote
Yes, also Garrett... but why do you want to know? It won't even fit in your car. It's a VNT-20 turbo that definitely achieves 1.5 bar of boost pressure. As far as I know, that's the standard boost pressure. 1.8 bar should actually be achievable.
cu
I also own a 150 PD GTi! That's why I wanted to know. Thanks for your answer. But how much boost does it actually produce?
Best regards, Sebastiaan.
Translated on 25-10-2026, 5:00.
No new posts VAG-COM: Generate Readiness Codes On-Board Diagnostics (OBD)
