Polo G40: Diagnose Interface Problems & Solutions
benjamin
Post26-09-2002, 20:47    Subject: Polo G40: Diagnose Interface Problems & Solutions Quote
Hi everyone!
I recreated the interface of http://hal9000.vc-graz.ac.at/3rdfloor/projects/diagnose/Diagnose-Interface.htm and connected it to my laptop using a registered version of VAG COM 0.78. Under the 'options' menu, 'test,' it recognizes the interface as OK. However, I cannot establish a connection to the car. It's clear that the ignition needs to be on, and I also understand what the K and L pins, as well as the plus and minus connections, are. Here's a picture of the interface:
Sure, I'd be happy to help. Just let me know what you need.
best regards, benjamin
Translated on 10-10-2026, 21:44.
Post27-09-2002, 14:18    Subject: Adapter Problems: Troubleshooting & Solutions Quote
Hi.
The resolution of your link's download is too low to be able to recognize the details of the circuit.
For a DIY option, I can suggest my version, which is available on Rainer's website via the link about adapters.
It seems your device is experiencing the old problem where the "response transistor" (which is driven by the K-line through only one resistor) is not properly switching off in practice.
Perhaps adding an additional resistor in parallel with the base-emitter path, with a value approximately equal to 1/10 of the kOhm value of the resistor between the base and the collector, might be sufficient.
Translated on 10-10-2026, 21:46.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts 1Z Tuning: Diagnose Problems & Solutions On-Board Diagnostics (OBD)
No new posts OBD2 Adapter for VW Passat 3C Diagnostics On-Board Diagnostics (OBD)
No new posts V6 TDI AKN issues with setting the injection timing using... On-Board Diagnostics (OBD)
No new posts Question about Maik's VAGCOM interface Diesel Engine Technology
