PaPa Guest
29-05-2005, 11:22 Subject: Coding Climate Control for 4-Cylinder TDI? |
Hello everyone
I recently installed an automatic air conditioning system in my Audi 80 B4 1.9 TDI (1Z).
The engine control unit came from a 6-cylinder coupe.
I am now looking for the correct encoding for this control unit.
original was it: 00060
The '3rd' 'Zero' refers to the Zexel compressor, the '6' refers to the 6-cylinder engine, and the 'Zero' at the end refers to the left-hand drive gasoline engine.
I am interested in coding for a 1Z engine, as I have only found coding information for gasoline engines in VW documents.
Maybe someone of you has a B4 or even an A4 with climate control and the climate control panel, and could maybe read out the coding from this?
Thank you in advance.
wolfi_b Profi-Schrauber
30-05-2005, 7:27 Subject: Coding Climate Control for 4-Cylinder TDI? |
As far as I know, there was no automatic climate control system available as an original equipment option on the B4 with 1Z.
Do you have a compressor and bracket, hoses, condenser, etc. from a 1Z with manual air conditioning? 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
PaPa Guest
30-05-2005, 13:11 Subject: Coding Climate Control for 4-Cylinder TDI? |
Yes, they were from a B4 1.9 TDI (1Z) Avant.
I got it very cheaply from a car that was involved in an accident.
Ich brauch jetzt eben nur noch die richtige Codierung.
Best regards
30-05-2005, 19:26 Subject: Coding Climate Control for 4-Cylinder TDI? |
There was also the 1Z with automatic. Climate control, right out of the box.
Use 00040 as a 4-cylinder coding.
