Marzocchi Blaumann
Joined: 01/05/2004 Posts: 238 Karma: +2 / -0 Location: Gummersbach
CAN Support
08-06-2005, 14:24 Subject: Does the transmission fit the ALH? |
Hello, can I install an EBJ transmission on an ALH engine in a Golf IV?
It's not listed in the transmission specifications for the ALH engine. Maybe someone here knows. Thank you, best regards, Bernd. Golf IV - ALH - Erstzulassung 9/99 |
Frank A. Blaumann
2000 Volkswagen Golf Free account, no CAN development support
09-06-2005, 11:53 Subject: Does the transmission fit the ALH? |
Yes, of course, this combination was also originally installed (e.g., in mine).
Best regards, Frank. '00 G4 ALH 170tkm , 11mm Pumpe, GGU-Getriebe |
Profile PM Garage |
Marzocchi Blaumann
CAN Support
09-06-2005, 12:32 Subject: Does the transmission fit the ALH? |
Thanks, I was wondering about that because the transmission isn't listed for the G4 in the forum, but it is listed for the A3.
Why did you modify yours? Did yours not hold up to the tuning?
How is it translated? Do you remember what your tire pressure was around 180 km/h?
Thank you! Golf IV - ALH - Erstzulassung 9/99 |
Frank A. Blaumann
09-06-2005, 12:48 Subject: Does the transmission fit the ALH? |
"No, it wasn't disassembled. I just found the long axle ratio in the ASD to be good, and I got it for a very good price." "That's when I thought I'd give it a try."
"Originally, it had a 0.756 ratio in the 5th gear, which was roughly 180 km/h at 4000 RPM (please don't focus on the exact 1-2 km/h difference, it was a while ago). Then I installed a 0.717 ratio, which resulted in approximately 190 km/h at 4000 RPM."
Profile PM Garage |
kixx_ass Blaumann
Joined: 03/02/2005 Posts: 75 Karma: +4 / -0 Location: Stuttgart
09-06-2005, 15:00 Subject: Does the transmission fit the ALH? |
hi bernd!
How is your renovation project going?
How many horsepower are you currently extracting from your ALH engine? Audi S2 QP
Sokda Superb 3T |
Marzocchi Blaumann
CAN Support
09-06-2005, 17:27 Subject: Does the transmission fit the ALH? |
@Frank, Thanks, sounds good. Didn't you recently have an engine failure, or was it someone else?
@kixxass
I'm currently waiting for my programmable engine control unit (ECU). In tuning mode, it should produce around 140 horsepower with 0.216-size injectors. Let's see how it performs. If it's not enough, I can also upgrade to 11mm pistons. Golf IV - ALH - Erstzulassung 9/99 |
Danilo100 Blaumann
Joined: 03/18/2004 Posts: 12 Karma: +7 / -0 Location: Dorsten
09-06-2005, 21:48 Subject: Does the transmission fit the ALH? |
The EBJ is compatible with your ALH; I've installed one in my car as well. Previously, I had an EGR with the same axle ratio and transmission gearing as the EBJ.
Best regards, Danilo. Golf 1J/5, Bj99 MKB: ALH , GKB: EBJ , GRA, Box
VW Passt 3BG Variant AVF, 6 Gang, GRA
Skoda Octavia Combi 2.0 TDI BKM DSG 170PS |
Profile PM Email |
