Audi A4 2005: Diagnostic Port & Connector
Beany
Karma: +1 / -1   Thank you, like it!
Post16-08-2005, 9:44    Subject: Audi A4 2005: Diagnostic Port & Connector Quote
...can anyone tell me where I can find it? And what kind of VAG-COM (which version or higher?) would I need for that?
Sure, here's the translation:
"Thank you."
Golf IV TDI PD - ASZ ERF MJ02 chipping @165PS
//www.spritmonitor.de/image_112485_1.png
Translated on 11-08-2026, 5:54.
Post16-08-2005, 11:36    Subject: Audi A4 2005: Diagnostic Port & Connector Quote
You probably already have the A4 type 8EC/8ED. In that case, you need a system with CAN bus support.
http://shop.dieselschrauber.de/index.php/cPath/23
16-pin diagnostic connector: Unfortunately, I don't know the exact location offhand, but it's generally located somewhere near the steering wheel, below the driver's side hood release lever, or in the center console (ashtray area). Usually, there's a cover plate (approximately 6x2cm) over it for aesthetic reasons.
Translated on 11-08-2026, 5:55.
vagtuning
Post16-08-2005, 13:31    Subject: Audi A4 2005: Diagnostic Port & Connector Quote
The left driver's footwell, near the hood release lever, exactly as described above, is correct 100%.
Translated on 11-08-2026, 5:56.
Ross-Tech-Support
Post16-08-2005, 17:20    Subject: Audi A4 2005: Diagnostic Port & Connector Quote
A CAN interface is not necessarily required; it ultimately depends on the engine type and equipment. However, it's difficult to say for sure beforehand, as we don't have the exact specifications. Here's a small list that might be helpful.
http://www.ross-tech.com/vag-com/cars/applications/a4s4.html
At least VAG-COM 504.1 is required, but for this model, the latest beta version 506.0 is recommended!
http://www.ross-tech.com/vag-com/download/beta/current.html
Translated on 11-08-2026, 5:57.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 2.5 TDI: Logbook, 2005, Allroad, Tip Upload
No new posts Audi A6 2.5 TDI Allroad: Logbook, Tips & Tricks Upload
No new posts Audi A6 2.5 TDI Allroad: Logbook, 2005 Upload
No new posts Log´s 3,8,11 Audi A6 Allroad 2.5 TDI Tip. 2005 BAU Upload
