Coding Climate Control for 4-Cylinder TDI?
PaPa
Post29-05-2005, 10:22    Subject: Coding Climate Control for 4-Cylinder TDI? Quote
Hello everyone
I recently installed an automatic air conditioning system in my Audi 80 B4 1.9 TDI (1Z).
The engine control unit came from a 6-cylinder coupe.
I am now looking for the correct encoding for this control unit.
original was it: 00060
The '3rd' 'Zero' refers to the Zexel compressor, the '6' refers to the 6-cylinder engine, and the 'Zero' at the end refers to the left-hand drive gasoline engine.
I am interested in coding for a 1Z engine, as I have only found coding information for gasoline engines in VW documents.
Maybe someone of you has a B4 or even an A4 with climate control and the climate control panel, and could maybe read out the coding from this?
Thank you in advance.
wolfi_b
Post30-05-2005, 6:27    Subject: Coding Climate Control for 4-Cylinder TDI? Quote
As far as I know, there was no automatic climate control system available as an original equipment option on the B4 with 1Z.
Do you have a compressor and bracket, hoses, condenser, etc. from a 1Z with manual air conditioning?
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
PaPa
Post30-05-2005, 12:11    Subject: Coding Climate Control for 4-Cylinder TDI? Quote
Yes, they were from a B4 1.9 TDI (1Z) Avant.
I got it very cheaply from a car that was involved in an accident.
Ich brauch jetzt eben nur noch die richtige Codierung.
Best regards
Ross-Tech-Support
Post30-05-2005, 18:26    Subject: Coding Climate Control for 4-Cylinder TDI? Quote
There was also the 1Z with automatic. Climate control, right out of the box.
Use 00040 as a 4-cylinder coding.
No new posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts PD Injector Data: 3-Cylinder Engine Performance Technical Data
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts Climate Control Retrofit: Installation & Guide Diesel Engine Technology
No new posts A6 Climate Control: Features & Functions Diesel Engine Technology
No new posts Sharan Climate Control: HE Mode Explained Upload
