Hello, I'm referring to the following thread because I'm experiencing the exact same problem.
/viewtopic.php?t=1870&highlight=j393
First, I will try to replace the capacitor.
If this doesn't work, I will obtain a replacement part.
My question: Besides pairing the keys, is there anything else I need to be aware of when replacing the device? I bought an interface cable and VAG COM for that.
The engine control unit (ECU) that needs to be located has the part number: 1C0 959 799 B.
Best regards.
bille-online...
