Torque-Master Guest
02-07-2002, 21:54 Subject: Boost Gauge for 150HP TDI Engine |
Hello everyone,
I've read a lot in this forum about connecting a boost gauge, but most of the discussions have focused on gasoline engines.
Can anyone tell me where I can connect the gauge in the engine compartment of my 150HP TDI  ? There are so many hoses everywhere!
Does anyone have a photo of the location that they could send me, or a foolproof description?
Please help me.
Translated on 27-10-2026, 5:55.
TDI 180 Guest
02-07-2002, 23:13 Subject: Boost Gauge for 150HP TDI Engine |
Hi Torgue Master, are you happy with your car? Is it fun to drive, with all that torque!
Unfortunately, I can't help you with the boost pressure gauge, but I might want to install one myself.
Have a lot of fun driving!
Sebastiaan.
Translated on 27-10-2026, 5:56.
03-07-2002, 10:17 Subject: Boost Gauge for 150HP TDI Engine |
Regarding the ad: Please use the search function to find related posts, as there were quite a few. The statement "only gasoline engines were discussed" is definitely incorrect; this is a TDI forum, and everything that has been discussed so far about boost gauges has exclusively been related to TDIs.
You need to connect it behind the charger, in front of the engine. Someone who owns the same car should be able to tell you the exact location in the engine compartment. A helpful tip for installation, including a post by Ulf, discusses the installation in an Ibiza TDI with 90 horsepower, as the connection point mentioned there should also be available on your car. You can likely find it using a search engine, although I don't have the link readily available.
Jan.
1Z5 CFHF  / AHB H4D
Translated on 27-10-2026, 5:58.
Profile PM Garage |
Torque-Master Guest
03-07-2002, 23:29 Subject: Boost Gauge for 150HP TDI Engine |
Thank you, I will jack up the car and do some more research.
Translated on 27-10-2026, 5:59.
Animalking Guest
21-08-2002, 15:44 Subject: Boost Gauge for 150HP TDI Engine |
The provided link is not working!
I also own an ATD and I'm looking for a pressure connection.
Translated on 27-10-2026, 6:00.
21-08-2002, 15:52 Subject: SEO-optimierter Titel (max. 60 Zeichen) |
Hi.
Probably the link doesn't work anymore because the old forums are only available as a zip file.
Here are some excerpts from the original post:
Quote: | . . .Because the car has an electronic boost pressure sensor, there is unfortunately no boost pressure hose that can be tapped into for the engine computer.
Instead of using the original fitting, I used a pipe section with an EGR valve and a shut-off valve. On one side, there's a diaphragm housing for the shut-off valve. Conveniently, I found similar threaded holes on the other side. I drilled one of these all the way through and screwed in a custom-made pressure nipple from the outside – and the connection was complete.
Thanks to a boost pressure gauge with a vacuum range, you can now monitor the function of the bypass valve simultaneously, and if there are any problems, check whether the valve has closed unintentionally while the engine is running.
Note: To safely prevent drilling debris from entering the intake manifold , it is recommended to remove the EGR component and thoroughly clean after drilling.
Translated on 27-10-2026, 6:01.
Profile PM Garage |
Animalking Guest
21-08-2002, 15:59 Subject: Boost Gauge for 150HP TDI Engine |
I own an ATD 100 hp TDI PD!
Isn't it safer to disconnect the hose that leads to the boost pressure limiting solenoid valve?
That should work well with a T-piece, right?
Here's the translation:
'I have another question: there are two connections on my boost pressure gauge!'
one for the pressure pipe and one black cable!
Does the display require a power supply, or what could the cable be for?
Sorry for the silly question, but I'm installing the ad for the first time!
Translated on 27-10-2026, 6:03.
21-08-2002, 16:08 Subject: It won't work, guaranteed! *lol* |
Animalking wrote: | I own an ATD 100 HP TDI PD!!!
That should work well with a T piece, right?! |
Hi.
The tapping is certainly easy to do... but that way you won't get boost pressure, but rather the underpressure for the turbocharger control to the display  .
Quote: | There's another question about my boost gauge; there are two connections attached to it!
Sorry for the silly question, but I'm installing the advertisement for the first time | .
Generally, the positive (+) cable is for the lighting, and the ground is connected to the instrument housing.
Translated on 27-10-2026, 6:05.
Profile PM Garage |
Animalking Guest
21-08-2002, 16:11 Subject: Boost Gauge for 150HP TDI Engine |
Okay, so I need to remove the large intake manifold flange in front of my EGR valve, right? I think it's best to remove it beforehand and clean it thoroughly after drilling.
Translated on 27-10-2026, 6:07.
21-08-2002, 16:33 Subject: Hose: Schlauchhosen für Damen & Herren. |
Animalking wrote: | | So, I need to remove the large intake manifold flange in front of my EGR valve, right??? I think it's best to remove it beforehand and clean it thoroughly after drilling!! |
Hi.
Okay, so I've equipped my 90 horsepower engine with an LDA (Low-Dust Accelerator).
I didn't connect to that hose; instead, I tapped into the metal part with the large AGR membrane canister.
I highly doubt that it looks significantly different in the case of PD.
Translated on 27-10-2026, 6:08.
Profile PM Garage |
eike Guest
25-08-2002, 12:49 Subject: Hose? |
Moin, ich habe den Ladedruck folgendermaßen angezapft: einfach die Kanüle einer etwas größeren Arztspritze ( ca Infusionsgröße ) durch den dicken Gummischlauch vor dem Ansaugkrümmer / AGR stecken und etwas fixieren. Die Kanüle habe ich etwas eingekürzt und auf das Ende, das normalerweise auf der Spritze sitzt, einen passenden Plastikschlauch gesteckt und mit einem Kabelbinder befestigt. Das It works well.
Eike.
