Replacing the control unit
klempnerkai
Post12-06-2005, 16:33    Subject: Replacing the control unit Quote
I'm having a problem replacing the engine control unit. I assume the T4 has immobilizer 2, with a 4-digit PIN, etc. However, when I access the immobilizer control unit (25) and then go to the login screen (11), and enter the 4-digit code from the trailer, including a leading zero, I get an error message saying that the code is incorrect. What now?
What am I doing wrong? I've actually read everything related to this topic using the search function, but apparently, I haven't read enough.
I would appreciate it if someone could help me.
Kai.
donalexo
Post12-06-2005, 22:12    Subject: Replacing the control unit Quote
Hello Kai!
You don't need a login for the instrument cluster in Immo II to program the immobilizer.
Simply select the combination, go to "Adaptation," and choose block 0. Save the value 0 and confirm. Turn the ignition on/off, and that's it, it's done icon_wink.gif.
Alex.
Touran 1.9 TDI, EZ 09/2004
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts Replacing the AFN control unit in an Audi A4 On-Board Diagnostics (OBD)
No new posts Replace Airbag Control Unit: Guide & How-To On-Board Diagnostics (OBD)
No new posts Replacing the J393 comfort electronics control unit On-Board Diagnostics (OBD)
No new posts Airbag Control Unit: Coding Only? On-Board Diagnostics (OBD)
