AFN-MSG pinout
frankm
Post15-06-2005, 20:31    Subject: AFN-MSG pinout Quote
Hello.
Let me introduce myself with a request. My name is Frank, I'm 48 years old, married with two children, and I'm currently working on my VW T3 van. It has a 1.9 TDI engine (MKB). "I installed an aftermarket radio (AFN) into a Passat 3B from 1999 and am now working on the wiring."
I've found everything except the diagnostic cables (K-line).
It's not listed in the wiring diagram for the motor harness, and the electrician at the dealership couldn't help me either. Can anyone tell me where I can find this wire? The engine control unit has the part number 038 906 018 P and features 80 pins across two connectors.
I'd like to say thank you.
Frank.
Wladi
Post16-06-2005, 8:51    Subject: AFN-MSG pinout Quote
Hello.
The K-line is located on pin 45 in the Passat.
and proceeds as follows:
Engine Control Unit (Pin 45) -> (Pin 5) Instrument Cluster + WFS (Pin 25) -> (Pin 7) Diagnostic Connector.
Okay, hier ist die Übersetzung:
'Vlad.'
frankm
Post16-06-2005, 13:34    Subject: AFN-MSG pinout Quote
Hello Wladi.
I will check that later. I hope it's the same for me.
First of all, thank you.
Frank.
PS: According to my plan, it should be a 0.35mm green/black cable.
No new posts Diagnostic connector pinout Diesel Engine Technology
No new posts ECU Pinout 1Z for GRA System On-Board Diagnostics (OBD)
