What kind of plug do I have?
leo_b
Avatar-leo_b
Post18-05-2005, 14:59    Subject: What kind of plug do I have? Quote
hi,
Sure, I can look it up, but it would be helpful if someone knew the following.
Do I have the 8-pin or 10-pin ESP connector?
and which pump is it? a VP37 or a VP44?
mkb: ajt (no translation needed as it appears to be an abbreviation or code)
gkb: you're welcome.
ps: 88
kw: 65
(No translation needed as the input is already in English.)
best regards, michael
Translated on 17-07-2026, 13:46.
rinderwahnsinn
Post18-05-2005, 20:27    Subject: What kind of plug do I have? Quote
So, in cases like that, I open the hood and take a look...
100% reliable method, faster and less annoying!
Translated on 17-07-2026, 13:48.
leo_b
Avatar-leo_b
Post19-05-2005, 8:32    Subject: Nice! Quote
hi everyone,
It's interesting how quickly one can accumulate negative points here.
But maybe my question is too simple.
I would really like to know where the line is drawn here, between what constitutes a meaningful question and what doesn't!
@rinderwahnsinn:
Sorry for bothering you!
rinderwahnsinn
Post19-05-2005, 8:55    Subject: Re: nice! Quote
Simply put, it doesn't make sense for me to spend an hour sifting through documents right now just to find out which pump is installed on your rather rare engine.
Taking a look under the hood and disconnecting the connectors only takes 5 minutes and gives you complete peace of mind. Documentation is often poorly maintained. Greetings to VAG and Opel!
Translated on 17-07-2026, 13:50.
leo_b
Avatar-leo_b
Post10-06-2005, 17:14    Subject: That idea about the hood was a good one... Quote
... however, I tried with the T4 without success.
As you probably know, the connector is located on the oil pan.
To do this, you need to remove the underbody panel.
I didn't know that.
and it's the one with 10 pins.
I received help from other members here via private message.
You're very welcome.
Translated on 17-07-2026, 13:51.
syncro peter
Post10-06-2005, 18:20    Subject: What kind of plug do I have? Quote
@rinderwahnsinn
Off-topic.
which pump is on your rather rare engine.
approximately as rare as an afn icon_wink.gif.
Translated on 17-07-2026, 13:52.
No new posts suche stecker Diesel Engine Technology
No new posts Flat Pin Connectors & Housing - 10 Cent Diesel Engine Technology
No new posts ESP Connectors: 8-Pin vs. 10-Pin Diesel Engine Technology
This topic is locked, you cannot edit or reply. OBD2 Adapter Cable for VW Golf 4 Diesel Engine Technology
