TDI Graph and AKN?
René_S
Post12-06-2005, 12:34    Subject: TDI Graph and AKN? Quote
Can I display the start of the injection on my AKN (likely referring to an engine control unit) using a TDI graph? The AKN cannot be selected in the MKB selection.
What comparable MKB (German classification system for occupations) codes can I use?
Thank you very much.
René.
Post12-06-2005, 13:24    Subject: TDI Graph and AKN? Quote
The TDI timing tool is only for engines with a distributor injection pump.
Do you have a repair manual for the AKN?
René_S
Post12-06-2005, 19:32    Subject: TDI Graph and AKN? Quote
Hello Rainer,
I have a VP 44 and a repair manual. The injection start time, measured in the baseline program, is 2 or 14 degrees (duty cycle 23/100) - which is within acceptable limits.
The reason for my inspection is a louder-than-normal noise from the engine and a lack of power when the engine is cold.
René.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post18-06-2005, 22:52    Subject: TDI Graph and AKN? Quote
Okay, I find that the V6 TDI engines are always very noisy, especially when they're cold.
And if the operating temperature hasn't been reached yet, they don't perform as well either.
It's generally not good to rev a cold engine.
B.Eng (FH) u. KFZ Meister
mserge
Post13-07-2005, 16:03    Subject: TDI Graph and AKN? Quote
To the best of my knowledge, you can't do that with the graph. I have an AFB (presumably referring to a specific document or system), and I found the answer in the manual. I don't quite remember the exact procedure, but I believe it should be read using the data blocks, not the TDI graph.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
No new posts TDI Engine Light: Causes & Fixes Diesel Engine Technology
No new posts AFN not in TDI graph On-Board Diagnostics (OBD)
No new posts TDI Graph: Analyze & Optimize Engine Timing On-Board Diagnostics (OBD)
No new posts TDI Graph Settings: Optimize Your Results On-Board Diagnostics (OBD)
