Passat Electrical Issues: VAG COM Fault Codes 18080 & 16955
bfp169
Karma: +0 / -1   Thank you, like it!
Post08-07-2005, 14:51    Subject: Passat Electrical Issues: VAG COM Fault Codes 18080 & 16955 Quote
I'm currently experiencing an electrical problem with my Passat Variant (2001, 74 kW).
VAG COM is detecting the following problems:
Address 01: -------------------------------------------------------
Controller: 038 906 019 BM
Component: G000SG 1238
Coding: 00002
Shop #: WSC 05311
WVWZZZ3BZ1E083939 VWZ7Z0Y2955851
2 faults found:
[g]18080 - Coolant Fan Control 1: Open circuit or short to ground.
P1672 - 35-10 - - - Intermittent
Cooler fan control 1: Short circuit to ground.
16955 - Brake Switch (F): Implausible signal.
P0571 - 35-00 - -
Brake light switch - implausible signal.
Readiness: Not applicable.
These errors cannot be icon_evil.gif deleted, but if I use the air conditioning for a long time, I have NO icon_question.gif errors. I only get errors related to the air conditioning and brake light switch together, or not at all!
Thank you for the help, and please forgive any language or grammar mistakes icon_redface.gif! I am learning German as my fourth language.
Who can help me?
Translated on 19-08-2026, 19:47.
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
No new posts Boost pressure on A3 1.9 PD ASZ engine, electrical proble... On-Board Diagnostics (OBD)
No new posts Error 16955/17978: Causes and Solutions On-Board Diagnostics (OBD)
No new posts Passat V6 TDI: Troubleshooting & Common Problems Diesel Engine Technology
This topic is locked, you cannot edit or reply. EPB Problem: Passat 3C, 2009 Model Transmission, Chassis, Body & Interior
