VCDS-Mobile®, HEX-NET® Interface | Messaggi 16+
Vai a pagina: Indietro  1, 2, 3  Avanti
Messaggio20-09-2016, 18:03    Oggetto: Cita
@klahauiVisualizzazione profilo: klahaui: Entrambe le cose. Il dispositivo HEX-NET può funzionare sia come punto di accesso autonomo, sia integrarsi in una rete Wi-Fi esistente.
Messaggio27-09-2016, 10:59    Oggetto: Cita
Bello, quando non ci sono più grovigli di cavi nel vano piedi.
Codice:
VCDS-Mobile
Auto-Scan
Finished
VIN: WAUZZZ8P8AB0*****
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 47 52 56 61 62 72
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine  (CFFB J)   Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 AB   HW: 03L 906 018 AG
   Component: R4 2,0L EDC   H20 6744
   Revision: 41H20---
   Coding: 00190012042401080000
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_ECM20TDI01103L906018AB 003006
   ROD: N/A
   VCID: 6A9751AB15F16135B92790EB86-803F
   No ASAM data for: "EV_ECM20TDI01103L906018AB"
No fault codes found.
Address 03: ABS Brakes  (J104)   Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AJ   HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 11424012092400FC881102EC902000523D0800
   Shop #: WSC 00046 412 12345
   VCID: 7AB761EB6551C9B549C740ABD6-802F
Address 08: Auto HVAC   Labels: 8P0-820-043.lbl
   Part No SW: 8P0 820 043 BN   HW: 8P0820043BN
   Component: KlimavollautomatH09  0150
   Revision: 000016     Serial Number: 8P0820043BN
   Shop #: WSC 00000 000 00000
   VCID: 79B57EE7605742AD40BD37BFCB-802C
Address 09: Cent. Elect.  (J519)   Labels: 8P0-907-063.clb
   Part No SW: 8P0 907 063 A   HW: 8P0 907 063 A
   Component: BCM PQ35  M   105 0575
   Revision: 00105 AK
   Coding: 06000A2FB0051AC0207040E00100815C437A2AAA006DC12AE4008F800041
   Shop #: WSC 00046 412 00000
   VCID: 322789CBFDA1F1F5C1F7284B6E-8067
   Subsystem 1 -    Part No SW: 8P1-955-119-F   Labels: 1Kx-955-119.clb
   Component: Wischer AU350H10 0040
   Coding: 00DD13
   Subsystem 2 -    Part No SW: 8K0-910-557   Labels: 8K0-955-559.clb
   Component: REGENLICHTSENH04 0003
   Coding: 024C2D
Address 10: Park/Steer Assist  (J446)   Labels: 8P0-919-475-7X2.clb
   Part No SW: 8P0 919 475 H   HW: 8P0 919 475 A
   Component: PARKHILFE 8K  H06 0120
   Revision: 11001001
   Coding: 000203
   VCID: 43C9DC0F521B487D5AA1E53789-8016
Address 15: Airbags  (J234)   Labels: 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 P   HW: 8P0 959 655 P
   Component: Airbag AU1042 H06 0160
   Revision: --------
   Coding: 30314238303830303035554A304C38503053
   ASAM Dataset: EV_Airba10AURB4 001001
   ROD: N/A
   VCID: 4FE1E03F8E53A41DCE1969A7E5-801A
   No ASAM data for: "EV_Airba10AURB4"
   Subsystem 1 -    Serial Number: 3572DRB40000A955128Q
   Subsystem 2 -    Serial Number: 3582DRB40000AA191A0S
   Subsystem 3 -    Serial Number: 35128RB4000055CE4FD0
   Subsystem 4 -    Serial Number: 35228RB4000055102B22
   Subsystem 5 -    Serial Number: 35547RB40000571AD99Y
Address 16: Steering wheel   Labels: 8P0-953-549.lbl
   Part No SW: 8P0 953 549 K   HW: 8P0953549K
   Component: J0527           H37  0070
   Coding: 0000042
   VCID: 46CFC51B6129FD557DBF045B72-8013
Address 17: Instruments   Labels: 8P0-920-xxx-17-MY8.clb
   Part No SW: 8P0 920 932 C   HW: 8P0920932C
   Component: KOMBIINSTR. VDO H03  0990
   Revision: D0H03005   Serial Number: 2241J005051395
   Coding: 0004028
   Shop #: WSC 00870 204 96062
   VCID: 342B8FD307B57FC5D30B3E6344-8061
Address 19: CAN Gateway   Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 AF   HW: 1K0907951
   Component: J533  Gateway   H17  0233
   Revision:   H17      Serial Number: 1521J102150511
   Coding: E9A07F06100202042102
   VCID: 6B9954AF1A0BE03DC2319D1791-803E
Address 25: Immobilizer   Labels: 1K0-920-xxx-25.clb
   Revision: D0H03005   Serial Number: AUX7Z0J1FNH0PM
Address 42: Door Elect, Driver   Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 8P0 959 801 M   HW: 8P0959801M
   Component: Tuer-SG         H04  0100
   Coding: 0131252
   VCID: 45CDC2175C2FF64D74B5FB2F67-8010
Address 44: Steering Assist   Labels: 1Kx-909-14x-44.clb
   Part No SW: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 232     3001
   Revision: 00H17000
   Shop #: WSC 00046 000 90108
   VCID: 312586C7F8A74AEDB8ED1F5F63-8064
Address 46: Failed to respond
Address 47: Sound System   Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 E   HW: 8P4035382E
   Component: AB2 SUBWOOFERBOXH07  0180
   Revision: 00006      Serial Number: 92158067970178
   VCID: 362FB5DB11C96DD5ED1F549B22-8063
Address 52: Door Elect, Pass.   Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 8P0 959 802 M   HW: 8P0959802M
   Coding: 0131252
Address 56: Radio   Labels: 8J0-035-1xx-56.clb
   Part No SW: 8P0 035 186 S   HW: 8P0035186S
   Component: R Concert2+     H03  0280
   Revision: 00H03000   Serial Number: AUZ1Z3K6015202
   Coding: 0110011
   VCID: 42C7D90B4D01C1755197D80BBE-8017
Address 61: Battery Regul.  (J840)   Labels: 1K0-907-534.clb
   Part No SW: 1K0 907 534   HW: 1K0 907 951
   Component: Batt.regelung H17 0233
   Revision: --------
   Coding: 0303085A
   VCID: E893ABA38BFDCB252F13FAF328-80BD
   Subsystem 1 -    Part No SW: 1K0-915-181-E
   Component: J367-BDM     H07 0140
Address 62: Door, Rear Left   Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F   HW: 8P4959801F
   Component: Tuer-SG         H04  0050
   Coding: 0131216
   Shop #: WSC 00046 412 1012544
Address 72: Door, Rear Right   Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F   HW: 8P4959802F
   Coding: 0131216
   VCID: 43C9DC0F521BC87D5AA1E53789-8016
2 Faults Found:
01554 - Motors for Central Locking; Rear Doors; Lock
   012 - Electrical Fault in Circuit
00931 - Locking Module for Central Locking; Rear Right (F223)
   008 - Implausible Signal
End-------------------------(Elapsed Time: 03:09)--------------------------
Messaggio27-09-2016, 11:27    Oggetto: Cita
Prezzi VCDS-Mobile, HEX-NET:
Ci saranno due versioni: una più economica, limitata a 10 numeri di telaio, e una versione per officine, senza limiti sul numero di numeri di telaio.
VCDS-Mobile, HEX-NET disponibile nel negozio: https://shop.dieselschrauber.org/it/vcds-hex-net-p-327.php
F B
Messaggio03-11-2016, 8:28    Oggetto: Cita
Sarà possibile effettuare un cambio da connessione cablata a connessione Wi-Fi?
Cordiali saluti, Frank.
Messaggio03-11-2016, 9:31    Oggetto: Cita
F B ha scritto:
Sarà possibile eventualmente effettuare uno scambio da Wi-Fi a cavo?
Ciao Frank,
Vediamo, si sta valutando come gestire i clienti esistenti che hanno acquistato un sistema da noi negli ultimi 12 mesi.
Comunque, non ci sarà alcuna possibilità di sostituire un cavo vecchio di 10 anni con l'ultima versione gratuitamente. È improbabile che si possa ottenere un Audi A6 4G nuovo scambiandolo con un Audi A6 4B con 500.000 km, e non mi è del tutto chiaro perché dovrei riempire il concessionario di Audi con 500.000 km.
L'attuale interfaccia HEX-USB+CAN continuerà ad essere supportata da VCDS.
F B
Messaggio03-11-2016, 23:27    Oggetto: Cita
Personalmente, vorrei sostituire il mio cavo da 3 metri con un adattatore Wi-Fi.
Non abbassare il prezzo al punto da farlo diventare zero.
Ma potreste valutare una struttura a scaglioni.
Cavi con meno di 6 mesi di utilizzo: costo aggiuntivo di xxx Euro.
Cavi con più di 6 mesi di utilizzo: costo aggiuntivo di xxx Euro.
Più vecchio di 2 anni... ecc.
Questo limiterebbe le possibilità di acquisto di Audi con più di 500.000 km.
Inoltre, cavi e connettori sono soggetti all'usura e all'invecchiamento.
Certo, nessun problema. Ecco la traduzione:
'Per favore, considera questo come uno spunto di riflessione e non come una richiesta.'
E un'altra domanda:
Se il Wi-Fi funziona nel garage, significa che la connessione al vostro adattatore dovrebbe funzionare in generale?
Messaggio04-11-2016, 11:57    Oggetto: Cita
Ciao Frank,
Grazie per il tuo suggerimento, sì, probabilmente andrà così.
È importante che io spieghi cosa non è, perché ci sono persone che, seriamente, hanno tirato fuori cavi del 2006 e, dopo 10 anni di aggiornamenti gratuiti, nuove funzionalità e miglioramenti, mi hanno rimproverato perché, a loro dire, avrebbero "solo" bisogno del "cavo" nuovo... così non è.
Riguardo al Wi-Fi nel garage: È possibile, ma non è strettamente necessario. Il dispositivo HEX-NET può anche funzionare come punto di accesso Wi-Fi dedicato, e questa opzione è selezionabile.
Quindi, in garage non è necessario avere il Wi-Fi.
hkss
Avatar-hkss
2017 Skoda Yeti
Messaggio07-11-2016, 16:21    Oggetto: Cita
Sono soddisfatto del mio cavo, posso lasciarlo collegato anche durante la guida. Ho anche un supporto per laptop nella console centrale, cosa che probabilmente non tutti hanno.
Mi sembra che il nuovo adattatore sia piuttosto lungo: temo che durante la guida possa rimanere incastrato o addirittura staccarsi? Un movimento o un contatto interrotto, soprattutto se si stesse per staccarsi, non farebbe certo bene alla centralina.
Se esistesse un cavo di prolunga, si potrebbe posizionare l'adattatore in un punto più defilato (ad esempio, nello spazio sottostante il volante)?
Messaggio07-11-2016, 18:02    Oggetto: Cita
hkss ha scritto:
Quindi, io sono soddisfatto del mio cavo: posso lasciarlo collegato anche durante la guida - ok, ho un supporto per il laptop nella console centrale, cosa che probabilmente non tutti hanno.
Se esistesse magari un cavo di prolunga, così da poter posizionare l'adattatore da qualche parte dietro l'angolo (nel vano portaoggetti sotto il volante)?
Non preoccuparti, né uno dei due è caduto, e comunque non farebbe male al "quello" (quale?) centralina. icon_wink.gif
Messaggio08-11-2016, 16:58    Oggetto: Cita
Ciao Rainer,
Certo, posso provare a spiegarti la limitazione di 10 FIN (Financial Identification Number) sui dispositivi mobili.
Questa restrizione vale solo per un giorno? Cosa succede se demolisco o vendo il mio veicolo?
Grazie mille.
La limitazione si applica a 10 numeri di telaio (equivalenti al VIN, Vehicle Identification Number) per interfaccia , per interventi di manutenzione . Autoscan, visualizzazione dei valori di misurazione, lettura e cancellazione della memoria degli errori: questa funzione non richiede il numero di telaio.
Codifiche, personalizzazioni, accesso, ritardi nella fornitura dei servizi, ecc., quindi lavori di officina, sì.
Una volta che i 10 numeri di telaio sono stati utilizzati, i lavori di officina possono essere eseguiti solo sui numeri di telaio precedentemente registrati.
Dieci numeri di telaio dovrebbero essere più che sufficienti per un uso privato, chi possiede mai dieci automobili? Anche se una persona possiede un dispositivo specifico, può comunque effettuare codifiche su altri 5 veicoli e, ad esempio, leggere i codici di errore delle centraline su un numero illimitato di veicoli.
Per tutti coloro che effettuano interventi di manutenzione/riparazione su più di 10 veicoli, è disponibile la versione del prodotto
illimitata. La variante del prodotto è selezionabile nella parte inferiore sinistra della descrizione del prodotto.
È
possibile anche successivamente sbloccare ulteriori
numeri di telaio per il HEX-V2 o il HEX-NET.
Cordiali saluti, Rainer
FIN-Upgrade.pdf
 FIN-Upgrade bei VCDS HEX-V2 und HEX-NET für Servicearbeiten an mehr Fahrzeugen.
Scarica
 Nome file:  FIN-Upgrade.pdf
 Dimensione file:  156.65 KB
 Scaricato:  1215 volte
Hojo-Hörnchen
Messaggio08-11-2016, 23:37    Oggetto: Cita
Ciao Rainer,
Grazie per questa risposta completa icon_smile.gif.
Seat Ibiza 6L Cupra TDI.
BUK und GUC. 136.000 Km.
Messaggio11-11-2016, 19:25    Oggetto: Cita
Ho ricevuto ulteriori richieste riguardanti la messa in funzione del dispositivo HEX-NET® di Ross-Tech.
Quindi, il dispositivo HEX-NET può essere utilizzato normalmente tramite USB, proprio come il precedente HEX-USB+CAN. Non c'è molto da fare, basta installare il software, collegare il dispositivo e il gioco è fatto.
È probabile che la connessione a VCDS sul computer venga utilizzata più frequentemente tramite Wi-Fi, poiché ciò elimina l'usura dei cavi USB e, inoltre, evita la presenza di cavi che potrebbero interferire all'interno dell'auto. Per configurare questa opzione, è necessario impostare "Net" come connessione nelle impostazioni del programma VCDS.
A partire da quel momento, la rete HEX-NET può essere utilizzata normalmente, come se fosse collegata tramite cavo.
È inoltre possibile utilizzare il sistema tramite VCDS-Mobile®, ad esempio per l'utilizzo in mobilità con lo smartphone. Per accedere, è sufficiente digitare l'indirizzo IP di HEX-NET nel browser web dello smartphone.
*) Per quanto riguarda le ultime due tipologie di utilizzo e di collegamento, sorgono le seguenti domande:
- Qual è l'indirizzo IP di HEX-NET?
- Il sistema HEX-NET deve essere accessibile. Come posso configurare la connessione Wi-Fi al sistema HEX-NET?
L'indirizzo IP di HEX-NET è, per impostazione predefinita, 192.168.0.1. È possibile ottenere l'indirizzo IP collegando il dispositivo HEX-NET al computer tramite USB e avviando il software di configurazione HEX-NET.
La soluzione più semplice è utilizzare il
HEX-NET come punto di accesso Wi-Fi (AP), che è l'impostazione predefinita. In questo modo, il dispositivo HEX-NET crea una rete Wi-Fi, assegnandole come nome il proprio numero di serie (vedi immagine qui sotto).
Collegare il dispositivo al computer e si può utilizzare HEX-NET, sia tramite VCDS sul computer che tramite VCDS-Mobile.
VCDS-Mobile viene avviato inserendo l'indirizzo IP di HEX-NET come URL nel browser web; la password predefinita di HEX-NET è password.
È possibile integrare il sistema HEX-NET in una rete Wi-Fi esistente, il che è utile per le attività di un'officina. Per farlo, sono necessarie alcune conoscenze di base su IP e reti. In seguito, verrà fornita una guida o un video esplicativo.
La commutazione, che determina se il dispositivo HEX-NET funziona come punto di accesso o tenta di integrarsi in altre reti Wi-Fi, avviene tramite il pulsante rosso sull'interfaccia.
Basta premere il pulsante e attendere brevemente; durante la ricerca della rete Wi-Fi sul computer, apparirà come un punto di accesso, creando una rete separata. Ogni pressione di un tasto passa al profilo Wi-Fi successivo, e è possibile configurare più profili.
 HEX-NET als Access Point betreiben und mit VCDS verwenden.
 Dimensione file:  232.98 KB
 Visualizzato:  74014 volte
WLAN-HEX-NET.pdf
 Generelle und notwendige Info zur HEX-NET WIFI-Konfiguration bei Einbindung in vorhandene Netze.
Scarica
 Nome file:  WLAN-HEX-NET.pdf
 Dimensione file:  663.96 KB
 Scaricato:  2615 volte
Messaggio27-01-2017, 13:47    Oggetto: Cita
Ecco un video di presentazione aggiornato di HEX-NET. Poiché lo strumento di configurazione è stato modificato, è in arrivo un aggiornamento.
VCDS-Mobile®, HEX-NET® Interface | Messaggi 16+ - HEX-NET Getting Started Video.mp4
 Video zur Inbetriebnahme vom HEX-NET Diagnosesystem.
 Dimensione file:  33.36 MB
 Visualizzato:  7758 volte
Messaggio21-02-2017, 9:02    Oggetto: Cita
Configurazione Wifi di HEX-NET:
Il software VCDS viene fornito con il programma di configurazione dell'interfaccia VCDS, che consente di configurare la connessione Wi-Fi per il dispositivo HEX-NET. L'ultima versione del software VCDS è disponibile all'indirizzo http://shop.dieselschrauber.de/account.php (il tuo account cliente nel negozio Diselschrauber).
Ci sono 2 modalità WiFi diverse per il sistema HEX-NET. Come access point, crea una propria rete Wi-Fi; come client, può essere integrato in una rete Wi-Fi esistente.
Il dispositivo HEX-NET non deve essere collegato a un veicolo per configurare la connessione Wi-Fi. Collegate il vostro dispositivo HEX-NET al vostro laptop utilizzando il cavo USB fornito.
Avviare il software VCDS. Cliccare sul pulsante [Impostazioni] e quindi sul pulsante [Test di connessione]. Dovreste ricevere un messaggio che indica che l'interfaccia è stata trovata e identificata come HEX-NET. Cliccate su [OK].
Ora, clicca sul pulsante "Configurazione" per aprire il programma di configurazione dell'interfaccia VCDS (VCIConfig.exe). Andare alla scheda Wi-Fi.
HEX-NET esegue la scansione di reti Wi-Fi e quindi elenca i risultati.
Selezionare la propria rete Wi-Fi, confermare con "Sì" o "Yes" e quindi inserire la password. Cliccare su [OK].
HEX-NET sta tentando di stabilire una connessione alla rete selezionata. Quando il dispositivo HEX-NET è connesso alla tua rete Wi-Fi in modalità infrastruttura, il LED centrale si illumina di verde.
Clicca sul pulsante "Aggiorna" nella lista delle interfacce.
Nella scheda "Panoramica", vengono visualizzate le informazioni sulla rete Wi-Fi a cui è connesso il dispositivo HEX-NET, nonché l'indirizzo IP che il router Wi-Fi assegna al dispositivo.
Il dispositivo HEX-NET può essere configurato per gestire fino a 7 reti Wi-Fi diverse.
VCDS-Mobile®, HEX-NET® Interface | Messaggi 16+ - HEX-NET WiFi Setup by Ross-Tech.mp4
 HEX-NET Wifi Setup (HEX-NET WLAN-Konfiguration)
 Dimensione file:  13.01 MB
 Visualizzato:  6221 volte
hkss
Avatar-hkss
2017 Skoda Yeti
Messaggio05-03-2017, 19:09    Oggetto: Cita
C'è un modo per vedere come appare su uno smartphone?
Sarei interessato se potessi visualizzare 4 o 6 elementi sullo schermo del mio smartphone.
potrebbero essere: "chilometri percorsi dall'ultima rigenerazione", "coefficiente di carico", "massa di cenere residua", "stato di rigenerazione"...
È possibile?
Nel forum della mia auto (Skoda Yeti), sta circolando un pezzo di ricambio di bassa qualità.
con cui, però, si ottengono risultati molto belli.
Naturalmente, per me, come cliente fedele di VCDS e RKS, non è assolutamente icon_smile.gif.
Messaggio05-03-2017, 19:18    Oggetto: Cita
Ho esaminato il componente "economico", tuttavia, a quanto pare, il supporto per i veicoli è valido solo per determinati modelli.
A mio parere, VCDS-Mobile è ancora in fase di sviluppo, come una versione alpha-beta, e consiglio di utilizzare il software per PC per lavorare. Riuscirà VCDS-Mobile a funzionare correttamente? Prova subito: qualsiasi dispositivo Android o iOS con connessione Wi-Fi è compatibile.
Nessun nuovo messaggio Addestramento T90 / T 91 con VCDS Errori e Documentazione (Audi, VW, Seat/Cupra, Skoda)
Nessun nuovo messaggio Reset DSG: Guida VCDS per principianti Errori e Documentazione (Audi, VW, Seat/Cupra, Skoda)
Nessun nuovo messaggio Stato della batteria con VCDS Errori e Documentazione (Audi, VW, Seat/Cupra, Skoda)
Nessun nuovo messaggio VCDS Mobile per Sharan 7N Diagnostica di Bordo (OBD)
Nessun nuovo messaggio App VCDS non disponibile nello store Diagnostica di Bordo (OBD)
Nessun nuovo messaggio VCDS Mobile: Problemi con i valori misurati? Diagnostica di Bordo (OBD)
Nessun nuovo messaggio Interfaccia VCDS per 24V Diagnostica di Bordo (OBD)
