Audi 80 B4,1Z,8C(Chassi) - Ultra plausible Fehercodes
Nuovo argomento 🔒 Bloccato 🔗 🖨 Dieselschrauber - Indice » Diagnostica di Bordo (OBD)
audi80
Messaggio20-10-2006, 12:23    Oggetto: Audi 80 B4,1Z,8C(Chassi) - Ultra plausible Fehercodes Traduzione in corso...
[Traduzione in corso...]
Hallo Leute!
Hab mal meinen Fehlerspeicher ausgelesen der folgendes liefert!
Codice:
Thursday,24,August,2006,17:55:54
VAG-COM Version: Release 607.2-D
Control Module Part Number: 8A0 907 401 B
  Component and/or Version: 1,9l R4 EDC A23     D09
           Software Coding: 00000
            Work Shop Code: WSC 00000
87 Faults Found:
00000 - End of Output
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        125-00 - Unknown Error Elaboration
07816 - Unknown Error Code
        15-00 - Adaptation Limit (Add) Not Reached
25600 - Unknown Error Code
        Unknown - 00-00 -  -
        00-00 -  -
00001 - Brake Control Unit
        112-10 - Unknown Error Elaboration - Intermittent
00240 - ABS Solenoid Valve; Rear Right (N56)
        40-00 - Short to Another Output
12810 - Unknown Error Code
        00-00 -  -
65295 - Development Code 16
        10-00 - Adaptation Limit Not Reached
00256 - A/C Pressure/Temperature Sensor (G395)
        00-00 -  -
00200 - Rear Interior Lamp Button (E327)
        01-00 - Signal Shorted to Plus
01801 - Door Warning Lamp; Drivers Side (W30)
        118-10 - Unknown Error Elaboration - Intermittent
00002 - Transmission Control Unit
        122-10 - Unknown Error Elaboration - Intermittent
01305 - Databus for Infotainment
05377 - Unknown Error Code
        19-00 - Lower Limit
03890 - Unknown Error Code
        00-00 -  -
10416 - Unknown Error Code
65533 - Unknown Error Code
        00-00 -  -
39679 - Unknown Error Code
        Unknown - 117-10 - Unknown Error Elaboration - Intermittent
56829 - Unknown Error Code
        Unknown - 01-00 - Signal Shorted to Plus
        07-00 - Signal too Low
00134 - Outside Door Handle Illumination/mirror Light Rear Right
        00-10 -  - - Intermittent
16327 - Unknown Error Code
        00-00 -  -
00100 - Drivers Interior Locking Button (E308)
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        123-10 - Unknown Error Elaboration - Intermittent
38232 - Unknown Error Code
        Unknown - 40-00 - Short to Another Output
36402 - Unknown Error Code
        Unknown - 00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        08-10 - Control Limit Surpassed - Intermittent
39296 - Unknown Error Code
        Unknown - 00-10 -  - - Intermittent
        00-00 -  -
00037 - Footwell/Cabin Temperature Differential Button (E305)
        17-10 - Control Difference - Intermittent
00512 - Camshaft Position (Hall) Sensor not at Reference Mark
        00-00 -  -
36146 - Unknown Error Code
        Unknown - 00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
Readiness: N/A
Saturday,02,September,2006,15:14:00
5 Faults Found:
01242 - Output Stages in Control Module
        06-10 - Signal too High - Intermittent
00523 - Intake Air Temp Sensor (G42)
        00-00 -  -
        00-00 -  -
        00-00 -  -
Readiness: N/A
Ein Autoscan ein wenig später brachte folgendes:
Codice:
Saturday,02,September,2006,14:19:50
Chassis Type: 8C - Audi 80 B4
Scan: 01 02 03 08 15 25 26
Address 01: Engine
   Part No: 8A0 907 401 B
   Component: 1,9l R4 EDC A23     D09
   Coding: 00000
   Shop #: WSC 00000
5 Faults Found:
            00-00 -  -
            00-00 -  -
            00-00 -  -
            00-00 -  -
Readiness: N/A
Address 03: ABS Brakes
   Part No: 4A0 907 379 A
   Component: Bremsen-Elektronik
No fault code found.
Address 08: Auto HVAC
   Part No: 4A0 919 579 C
   Component: Stg. Klimak. 4-Zyl. D07
1 Fault Found:
00532 - Supply Voltage B+
End   --------------------------------------------------------------------------------------------------
Adapter: AI USB ohne CAN (intelligent)
Symptome:
Leistungsverlust (speziell unten kein Drehmoment)
Vmax nicht errreichbar
Verbrauch: egal bei welcher fahrweise 9 bis 10 l
Vielleicht habt ihr ideen!
Georg
Ross-Tech-Support
Messaggio20-10-2006, 12:53    Oggetto: Audi 80 B4,1Z,8C(Chassi) - Ultra plausible Fehercodes Traduzione in corso...
Ich sag mal das ist ein Problem in der Kommunikation, das sieht man bereits daran das ein Motorsteuergerät dieses Baujahres gar keinen Platz für 87 Fehler hätte.
Welches Interface hast du denn genau? AI MultiScan USB? Ist eine aktuelle Firmware auf dem Interface? Auto-Intern Hardware benötigt eine separate Software zur Firmware Aktualisierung, dies läuft explizit nicht über die VAG-COM internen Routinen. Des Weiteren wäre es mal interessant mit einem HEX Interface auszulesen, ich lehn mich mal aus dem Fenster und stell in den Raum das sowas damit nicht passieren würde. Wo wohnst du? PLZ-Bereich?
audi80
Messaggio20-10-2006, 14:14    Oggetto: Audi 80 B4,1Z,8C(Chassi) - Ultra plausible Fehercodes Traduzione in corso...
Ich wohne in Österreich! (je nachdem in Kärnten / Osttirol / Salzburg)!
der vermeindliche kommunikationsfehler trat übrigens nur ein einziges mal auf!
Adapter: AI MultiScan USB (VAGCOM + dongelfunktion) mit neuerster firmware
Hatte übrigens schon einmal ein problem mit der kommunikation wo der Öamtc versuch hat ins steuergerät zu kommen mit 3 verschiedenen geräten (2 gutmann, 1 bosch) --> hatten keinen erfolg, obwohls mit dem bosch bereits schon einmal fuktioniert hat!
die fehler die mit dem bosch und dem AI adapter ausgelesen worden sind, sind bis auf das eine mal immer die gleichen:
Codice:
            00-00 -  -
            00-00 -  -
            00-00 -  -
            00-00 -  -
    wobei der fehler 00000 nirgendwo dokumentiert ist und immer öfter als einmal im fehlerspeicher steht. --> egal bei welchem auslesegerät.
    Aber vielleicht ist das auch gar kein fehler sondern ein EOF marker oder so!
    der fehler 01242 ist zwar dokumentiert aber nicht mit der "untergruppe" 06 - Signal too High, auch nicht im neuesten? original audi rep. leitfaden "Diesel-Direkteinspritz- und Vorglühanlage > 02.94" ausgabe 05.97
Stellglieddiagnose habe ich bereits durchgeführt, alles funktioniert bis auf die abgasrückführung da weis ich es noch nicht ob oder ob nicht funktioniert. da die membran im ventil am kümmer kaputt ist ( und zusätzlich die abgasrückführung verplattet/verstopft ist)
voller ladedruck ist da, baut sich aber erst recht spät auf, verschlauchung hab ich bereits auf dichtheit getestet.
LMM liefert, mit dem voltmeter gemessen eine schönes signal, von 0,xxx bis 5,xxx volt
die restlichen sachen (MWB 0, einzelmesswerte, ansteuerung abgasrückführung) werd ich hoffentlich am wochenende noch schaffen zu checken.
georg
Uwe@Ross-Tech
Messaggio20-10-2006, 16:53    Oggetto: Audi 80 B4,1Z,8C(Chassi) - Ultra plausible Fehercodes Traduzione in corso...
[Traduzione in corso...]Die fehler welche in der ganz langen liste angegeben werden sind mit fast 100% sicherheit nicht echt. Da gibt's irgend ein problem, entweder zwischen auto und interface, oder zwischen interface und VAG-COM.
Du solltest dich mit Auto-Intern in kontakt setzen.
Du kannst auch mal die normalle englische 607.3 von unserer download seite probieren, und uns sagen ob du damit das selbe problem hast.
http://www.ross-tech.com/vag-com/download/current.html
-Uwe-
Nessun nuovo messaggio Suoni di rombo, Audi A3 8P Errori e Documentazione (Audi, VW, Seat/Cupra, Skoda)
Nessun nuovo messaggio Sostituzione liquido freni Audi A4 8K Errori e Documentazione (Audi, VW, Seat/Cupra, Skoda)
Nessun nuovo messaggio Zuordnung Audi Typ, MKB, GKB, AKB, MJ Dati Tecnici
Nessun nuovo messaggio Interruttore volante Audi 80 RS2 = Audi A4 B5 ? Trasmissione, Telaio, Carrozzeria e Interni
Nessun nuovo messaggio FIS im Audi Trasmissione, Telaio, Carrozzeria e Interni
Nessun nuovo messaggio 2L TDI mit 170 PS im Audi A4 B7 Tecnologia Motori Diesel
Nessun nuovo messaggio Audi A8 4.0 TDI Tecnologia Motori Diesel
