Kopie meiner erhaltenen mail!
Thank you for your interest in our line of High Watt Density Universal
Preheaters for engines,
transmissions, hydraulic reservoirs, gear boxes, hydrostatics, etc. These
all comply with UL (Underwriters Lab) Approval #E95403. and are sized
according to the oil pan capacity.
Following is the price, each, for the 110vac LWD (Low Watt Density). It
comes
with pigtail electrical leads only, (no insulation pad, cord, plug or RTV
adhesive).
#10LWD (50 watt) $40.82; 2' X 5', for 1 - 3 quart engine oil pan
The following HWD (High Watt Density) Preheaters come with 7' cord and
grounded (3 wire) plug, insulation pad,
and RTV adhesive. With the insulation pad in position the heater and pad are
.050' thick.
#125W (92 watt) $46; 3' diameter, for 2 - 4 quart engine oil pan
#300W (234 watt) $57; 4' X 4.5' for 4 to 10 quart engine oil pan
#600W (455 watt) $71; 5' X 7' for 11 - 22 quart engine oil pan
#1100W (900 watt) $83; 6.5' X 10.75' for 22 - 48 quart engine oil pan
Following are prices, each, for 220vac HWD (High Watt Density) models. These
come with all of the
same features as the 110vac models except there is no plug on the cord.
Engine oil pan sizes and watt ratings are the same as for the 110vac models.
125W: $54; 300W: $70; 600W: $86; 1100W: $100
If one Preheater is not sufficient for your needs a second Preheater can be
added. If the dimensions for the correct one for your oil pan capacity are
too large, two smaller
ones can be used instead. If the bottom of the oil pan takes a lot of abuse,
such as in snow plow service or farming applications, mount the heater to
the side of the pan being
sure to keep the heater below the level of the oil.
We have added two new heaters (same construction silicone/fiberglass:
KB-7515 Battery Heater Pad 75 watt, 19' X 10.5'. Set the battery on top
and plug in to 110vac includes 6' three conductor cord and plug. $142.80
DRUMHEATER for 55 gal. steel drums, 1500 watt, 110vac. 4.5' wide with
adjustable thermostat, 6' three conductor cord with plug. Patent pending
hook & loop closure. Flexible, can be rolled up for storage. $275.00
Ask about our Low Watt Density preheaters.
Shipping and handling charges for United Parcel Service will be added to
your order within the continental U.S. as follows: 1 to 3 Preheaters @
$9.00; 4 - 6 Preheaters @ 11.00. Call for charges on more than 6 or for your
preference of shipping instructions. Special order Preheaters are quoted on
a per order basis.
Prices and specifications are subject to change without notice and prices
are subject to all applicable taxes and are quoted F.O.B. the factory or
North Aurora, IL USA.
Availability and Delivery is subject to wars, strikes and other events
beyond our control including availability on limited supply offers that are
subject to prior sale. Payment is to be in U.S. funds only. Checks are to be
paid through/to a U.S. bank. Terms are prepay or C.O.D. Master Card and
Visa are accepted.
E TIP is a Veteran Owned Small Business. Call us at ((630) 966-8992 or fax
us at (630) 801-9569; visit us at www.etipinc.com or email at
[email protected]
HB
