Audi A6 (AEL), cold start... idle speed sways
Neues Thema beginnen Auf Beitrag antworten Weitergeben, Thema teilen Lesezeichen setzen Druckansicht Dieselschrauber - Übersicht » On-Board-Diagnose (OBD) mit VCDS, Steuergeräte
mrfree
KFZ-Schrauber seit: 23.10.2006
Beitrag04-01-2007, 11:22    Titel: Audi A6 (AEL), cold start... idle speed sways Antworten mit Zitat
When I start my Audi A6 (AEL, 1995) in the morning (cold start) the idle speed sways between 1000 and 750 rpm and has difficult to start (it seems like only some cylinder starts well)
I tried with:
* double pre-heating (I'm not sure about this term in eng icon_smile.gif)
* setting timing a bit upper the regular values (using vagcom tdi-timing tool)
* accelerating a little bit during the start-up
Could this problem be related with G80 Implausible Signal (AEL)?
Thanks, in advance.
Karma: +26 / -0   Danke, gefällt mir!
Beitrag04-01-2007, 12:49    Titel: Audi A6 (AEL), cold start... idle speed sways Antworten mit Zitat
Hi Laurento,
are you sure all glow plugs are ok and heat well ?
Is the wiring of them as easy accessible as it is in other TDIs ? The 1Z allows to unplug the wire (in fact it's one metall-rubber piece) very easy by just pulling it off the glow plugs.
If the AEL allows this too, try to remove it and measure the resistance of the plug. It should be at 0.8 Ohms for a cold engine and cold plug.
After 11 years one or more plugs may be dead, which results in cold start problems and occurs not until winter.
I don't know what the fuck it was.
mrfree
Beitrag04-01-2007, 12:57    Titel: Audi A6 (AEL), cold start... idle speed sways Antworten mit Zitat
Hi Laurento,
I'll check them tomorrow using a tester and I'll post here the inspection-result icon_wink.gif
mrfree
Beitrag06-01-2007, 15:33    Titel: Audi A6 (AEL), cold start... idle speed sways Antworten mit Zitat
For 4 plugs the tester reports 0.8 ohm and for the remaining plug 0.7 ohm
May I make some other useful tests?
Keine neuen Beiträge Ladelufttemperatur am Audi A3 Fachartikel
Keine neuen Beiträge Bremsflüssigkeitswechsel Audi A4 8K Fehler und Dokumentation (Audi, VW, Seat/Cupra, Skoda)
Keine neuen Beiträge Zuordnung Audi Typ, MKB, GKB, AKB, MJ Technische Daten
Keine neuen Beiträge Audi A3 1,9tdi glühkerzen lampe blinkt nach start hilfe On-Board-Diagnose (OBD) mit VCDS, Steuergeräte
Keine neuen Beiträge ajm leistungsprobleme ruckeln idle.log Upload
Dieses Thema ist gesperrt, Du kannst keine Beiträge editieren oder beantworten. erfahrung speed buster power box Dieselschrauber Bar
Keine neuen Beiträge Schlechter kalt start mit viel Rauch Diesel Motorentechnik
