Polo MJ 2001.
"Airbag control light is illuminated. Error code "01317 Control unit in the dashboard panel, no communication" is registered in the airbag control unit."
Cause:
When the engine is started, the minimum supply voltage at the instrument cluster is exceeded. As a result, the error code 01317 is stored in the airbag control unit.
Solution:
In case of a complaint, replace the combined unit and clear the error memory of the airbag control unit. Tschüss
Michael II
Translated on 30-08-2026, 18:43.
