Electric to Manual Window Conversion
w123diesel
Karma: +7 / -1   Thank you, like it!
Post18-01-2007, 20:56    Subject: Electric to Manual Window Conversion Quote
Since this is the second time a friend's power window motor (driver's side) has failed within 3 years,
I'm wondering if it's possible to install a standard manual window crank without much effort.
The electric window motors are too expensive for me in the long run.
It's a Polo 6N, manufactured in September 1998, a 2-door model with a 1.4-liter gasoline engine, 60 horsepower, and 130,000 kilometers on the odometer.
Jürgen.
Translated on 15-10-2026, 19:12.
a dancer
Post18-01-2007, 22:43    Subject: Electric to Manual Window Conversion Quote
Perhaps I should go to a junkyard or a car recycling center and take the complete interior door panel with the mechanisms from a damaged car.
Translated on 15-10-2026, 19:13.
Herr Antje
Post19-01-2007, 6:34    Subject: Electric to Manual Window Conversion Quote
Maybe you've tried this before, but it helped me. I'm not used to these parts failing so often; it's usually the guides that break.
The electric motor repeatedly stops at the same point because it has "learned" to do so. This results in a "dead point." This is somehow related to the carbon brushes.
Mine was "broken" at one point, so I took it out. Then I tapped it lightly while starting the motor (separately from the guides). Eventually, it started working again. I then ran it for a very long time in both directions, reinstalled it, and it's still working.
The tip, by the way, came from my friendly icon_eek.gif.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 15-10-2026, 19:14.
w123diesel
Post19-01-2007, 11:48    Subject: Electric to Manual Window Conversion Quote
I've also hit it quite a few times.
He usually went away again for about 2-3 months, but now I'm fed up, or rather, my girlfriend is.
Best regards, Peter.
Translated on 15-10-2026, 19:15.
Herr Antje
Post19-01-2007, 11:50    Subject: Electric to Manual Window Conversion Quote
That's the thing, it just goes back to the same spot where it was before. If you expand it and let it run, you'll have more peace and quiet for longer. It's been about 3 years now.
Aktuell:
Translated on 15-10-2026, 19:16.
No new posts Window Repair: Audi A4 (1999) - Fix Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Luop 6X1 MJ 2002, Window regulators stiff Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Window lifter not functioning Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electric Window Failure: Complete System Malfunction Diesel Engine Technology
No new posts Window Motor Power Consumption Diesel Engine Technology
No new posts Golf 4 Window Regulator Replacement Transmission, Chassis, Body & Interior
No new posts Power windows with built-in intelligence? Diesel Engine Technology
